Old 12-10-2008, 08:28 AM   #1
bearguy is on a distinguished road
Hubs
i have a 2002 f350. if i lock the hubs in maually 4wheel drive works. turn the switch for the auotmatic and i hear it engage but no 4 wheel drive. can someone help
bearguy is offline   Reply With Quote
Old 12-10-2008, 09:21 AM   #2
You have a very common problem with the ESOF system. This "electronic shift on the fly" system is very problematic. These problems are often vacuum related. The hubs work on a pulsed vacuum system and should not be confused with steady manifold vacuum. You have either a leak in one or more lines. You have a leak at the seal in the hub assembly, or a bad vacuum module located under the hood.
Since the transfer case appears to work the actuator is functional, and it leads me to believe that you have a leak somewhere.
The lines at the hub tend to leak.
Old 12-10-2008, 09:58 AM   #3
+1 Like 75 said.
Old 12-10-2008, 10:22 AM   #4
Ditto, vacuum leak.
Replacing hubs vinniepro Ford Truck Forum 9 11-19-2008 06:50 PM
I need a set of DRW front 4x4 hubs ASAP!!!!!!!!!! Lonesome7.3 Truck Classifieds 7 08-01-2008 04:11 AM
4wd hubs won't engage riata_ag Chevy Truck Forum 16 03-29-2007 09:16 PM
Front Hubs on 2WD Jimmy S15 jktuck GMC Truck Forum 0 12-22-2006 02:37 PM
auto hubs colocat Ford Truck Forum 2 05-01-2006 05:47 PM
