| Full Member Join Date: Sep 2006 Location: Manitoba
| 4.6 oil leak?? We have a 2000 4.6 engine leak on a truck at work. It is coming out from behind starter it looks like. Stops leaking when down to add mark on dipstick. Is it the head gasket or pan gasket. |
| Those are notorius for head gaskets. If it is above the starter that is most likely your problem. |
| Check where the distributor is I think that's where to oil sending unit is at it might have a bad o-ring replace with a green o-ring. You can clean that area real good then pour some baby power/flour in that area so that you can see if it's leaking oil from that area might save you a lot of work. |
| A 4.6 does not have a distributor.. |
| 95 F-150 4x4 tranny leak | arkie4whlr | Ford Truck Forum | 2 | 10-10-2008 11:58 PM |
| Oil Leak.... | nnunez | Chevy Truck Forum | 3 | 01-17-2008 07:07 PM |
| water leak | rednekracer | Chevy Truck Forum | 35 | 10-29-2007 10:05 AM |
| oil leak | scottie | Chevy Truck Forum | 10 | 01-22-2006 07:00 AM |
| Just a little leak | 4x4 | Ford Truck Forum | 8 | 11-07-2005 01:55 PM |
