| Junior Member Join Date: Dec 2008 Location: snohomish, WA
| superduty lift kits how tall I have a f-350 super duty I want 35X12.50 but i tow 90% of the time. so i do not want to be to high, but have funtional, but nice looking. would a leveling kit or 4'' pro comp or 6.5 pro comp it might be to tall. thanks for any help. |
| Welcome to the site: This answer requires a little more info. What year is the truck. 99-04 trucks have leaf springs up front, and will require slightly different lifts to accomodate the same size tires. 08 and current trucks can fit 35's without much trouble. Much also has to do with the width of the tire with the wheels you intend to run. Are you towing a 5-er? or is this a bumper mount type trailer? |
| ford lifts 2004, I pull a jeep/car trailer. And 12ft cargo trailer for work @#5000 or so. Thanks |
| You can run any tire combo you want. You are haulin small loads. For your 35" tires you can consider either a 4 or 6 inch system Much will depend on how aggressive you are off road. What I mean is that if you are off road a bunch the 6" system is probably a better choice. You could rub the fenders at full suspension compression with 35" tires. Now if you are not to aggressive off road, then you can get away with the 4" system Icon (previously Donahoe racing) recommends either configuration for this size tire. You are not pulling a bunch of weight so either will do. Keep in mind that 6 inches is reaching the limits of the front driveshaft length, and you will either have to change or modify the brake lines. They start to get a little bit short at the 6 inch mark. |
| 4" lift is it. I am so glad I did not go 6.5 this would put me at mall cruser status. after all a desiel 4 door full size is no offroader unless it is freeway offroading. its just to big for serious offroading. but the lift is perfect. no one smart would go any higher. it looks nice. so it will work great it can tow my rock and mud machine around in style. thanks for all the help. |
| 88-94 lift kits for sale? | hockeyhead89 | Chevy Truck Forum | 10 | 10-14-2008 11:50 AM |
| lift kits | medic3616@sbcgl | Chevy Truck Forum | 12 | 09-26-2007 08:45 AM |
| Suspension lift kits | RichardLGriffin | Ford Truck Forum | 5 | 09-06-2005 06:05 PM |
| 03 Sonoma Lift Kits | brent0702 | GMC Truck Forum | 0 | 08-28-2005 09:19 PM |
| Too-Tall Truck Gets Stuck Under Overpass (KSAT ClickOnSA.com via Yahoo! News) | trucknews | Truck News (headlines) | 0 | 03-28-2005 10:30 AM |
