Old 02-06-2009, 10:21 PM   #1
batty1214's Avatar
What gear ratio? and traction aid?
So, I recently tore down my "free" 3/4 ton ford axles.(front hp D44 rear ford 9inch) and the gears are hammered. So, I guess i will be upgrading anyway. So, My question to Ya'll is, What gear ratio, and what traction aid would you all suggest?
They are going to be swapped under my 1993 S10, that is running a hopped up 4.3 with a tbi Im debating transmission, as I have a 700r4 and it also has the 5 speed in it as of now. I had it on the dyno with 235/75/r15 tires which it came with, and came up with about 215 horse...... and about 250 ft.lbs. of torque(little monster eh?) now I am planning on running 33-35 inch tires, and using it in the mud a little, but mostly in the rock trails that we have around the town. price isn't an issue, as I have been saving for about 3 years to begin this project.
Old 02-07-2009, 12:41 PM   #2
batty1214's Avatar
I have been thinking of 4:88 gears, and arb air lockers front and rear. but Im not sure if the 4:88 is low enough with only the 4.3 v6 any thoughts?
Old 02-13-2009, 07:21 PM   #3
This is an interesting question and much of this will have to do with the actual size of the tire. There is a difference between the 33 and the 35" tire. Are you sure this is the tire size that you intend to keep?
YOu will also have to decide on which trans you intend to keep. I like trucks with a bunch of gear, and run some steep gears on many of my trucks, especially any that might be short on power.
I like the 4.88 gear ratio for this, and might even consider the 5.13 range if you chose the auto and 35" tires.
This is a pretty popular swap for the vehicles in this similar category.
You are content with ARB's? What is it about them that you like? Detroits are not an option?
Old 02-13-2009, 09:56 PM   #4
batty1214's Avatar
detroit are an option. I haven't used any of them, But I do have some use with ARB... would you suggest detroits instead? and this past weekend I spent the day out with a buddy in the local 4x4 club, and 95% of them run 35's..... so I am thinking 35's, and building up the 700r4 and swap out the manual
Old 02-13-2009, 11:12 PM   #5
For 35 inch tires, probably any of the lockers are gonna hold up fine, I just like the strength advantages of the detroit. I seldom see the need to run a selectable unit, and the auto lockers are fine for my application.
Just a preference thats all.
Old 02-14-2009, 10:49 PM   #6
98k1500's Avatar
98k1500 will become famous soon enough98k1500 will become famous soon enough
this dude is einsteins brother of the redneck world.... 75 your ******* awesome.
98k1500 is offline   Reply With Quote
Old 02-17-2009, 10:04 AM   #7
eponator's Avatar
We <3 you 75!! LMAO!!
in all seriousness, hes a good guy who really knows his stuff. He will not steer you wrong Batty! Good luck with your build, I'm a fan of those year trucks myself and look forward to seeing this build!
'99 F350 5.4L crewcab Longbed
Gear ratio? chevyman_03 Chevy Truck Forum 7 10-26-2008 08:32 PM
Gear Ratio brad4eva Chevy Truck Forum 10 05-11-2008 11:32 AM
Likely gear ratio? 436'd skylark Chevy Truck Forum 13 12-19-2007 03:17 PM
Gear Ratio??? What If???? Maverick Chevy Truck Forum 11 07-27-2006 09:58 PM
Gear Ratio??? Billy2001Z71 Chevy Truck Forum 4 06-19-2005 02:27 PM
