| Starting it?? Last edited by gettembuilt; 02-17-2009 at 11:59 AM. Reason: error |
| All engines need good batteries to start. teh diesel has glow plugs and air warmers that draw power so the batteries have extra duty. make sure you change both, not just one
| Banned Join Date: Nov 2008
| leolkfrm pretty much covered it. All engines require a power source to crank the starter over, giving them the ability to start. Yes, diesels need more power to start, partly becase of the high compression, but also because of other factors like leolkfrom stated. If the batteries are old, change them. Otherwise you are only delaying the inevitable by charging them. Good luck. |
| Stumpuller will let you know he knows a lot about diesel engines. |
| The 7.3 turbo diesel needs minimum 100 rpm during cranking to achieve enough injection control pressure to open the injectors. |
| 454 starting issues | 98k1500 | Chevy Truck Forum | 44 | 02-14-2009 09:22 PM |
| Starting Problem | njk53 | Chevy Truck Forum | 2 | 02-05-2008 05:39 PM |
| Help truck is not starting | colbyj86 | Chevy Truck Forum | 6 | 12-03-2007 07:23 AM |
| School's starting! | Moostang | Off-Topic | 24 | 08-26-2007 01:25 PM |
| starting problems | tjh1075 | Dodge Truck Forum | 0 | 02-21-2007 03:33 PM |
