Old 02-26-2009, 04:24 PM   #1
rsutr101 is on a distinguished road
Newbie needs more help
I have a 1991 7.3 diesel when I drive home from work ( 10 mile drive ) and pull in my drive the truck runs rough then dies when I am applying the brake to stop. It will restart and run till I shut it off. This never happens in the morning going to work just in the afternoon at home
rsutr101 is offline   Reply With Quote
Old 02-26-2009, 04:56 PM   #2
look around the brake booster, and hose to it, for a vac leak
Old 02-26-2009, 05:03 PM   #3
ok That would cause it to die?
Old 02-26-2009, 05:07 PM   #4
oops thought it was gas, not sure on the ford diesel. we will wait to hear from the ford experts
Old 02-26-2009, 05:08 PM   #5
ok thanks though
Old 02-27-2009, 09:47 PM   #6
Check your trans fluid level.... May sound goofy but low fluid level will cause the converter clutch to lock up and kill the engine. A sticking TCC solenoid will do the same thing but check the fluid first.
Old 03-02-2009, 11:00 AM   #7
Good suggestion, provided he has an E4OD trans, unfortunately he doesn`t say.
It could also be a sticking governor in the injector pump. Might be worth running a can of a good fuel system cleaner thru it (like Lucas or Diesel Kleen).
Can`t see the braking can have anything to do with it.
Old 03-03-2009, 04:16 PM   #8
Sorry it is a E4od I will check the fluid level the tranny only has about 2000 mile on it. The guy i bought the truck from just replaced it with new not rebuilt and put a new ip on it too so I will check the fluid what and where is the TCC sol.have been running diesel fuel brand additive in every fill of the tanks
Old 03-04-2009, 08:55 AM   #9
I think tjzz4 has hit the nail on the head. Check the transmission fluid level with the trans in Park and at normal operating temperature. If it is good then another possibility is that the transmission internal fluid filter has become dislodged.
Old 03-04-2009, 11:10 AM   #10
The TCC solenoid is the torqye converter clutch solenoid and it is part of a solenoid body accessible by removing the pan. Your main trans harness plugs into it on the right side of the trans.
Good point on the filter becoming dislodged as well.
Newbie with a C30 coyconner1983 Chevy Truck Forum 4 02-07-2009 05:31 PM
Newbie GMCMUSCTRK Introductions 13 11-17-2007 08:43 AM
newbie here bigbass140 Introductions 1 01-20-2007 02:52 PM
Another newbie 87Sierra Introductions 1 12-29-2006 02:41 PM
Newbie dakotaguy. Dodge Truck Forum 27 09-14-2005 03:28 PM
