Old 02-26-2009, 11:00 PM   #1
uranium67's Avatar
uranium67 is on a distinguished road
accelerates and dies
Engine dies when I accelerate, but idles fine Running 292 engine
uranium67 is offline   Reply With Quote
Old 02-26-2009, 11:08 PM   #2
crabtruck's Avatar
Originally Posted by uranium67 View Post
Hey all, I recently bought a 1964 ford f100 custom cab,.....
It idles very rough and usually dies if the engine isnt revved. .....
when putting it in drive and reverse kills the engine quicker unless you revv the engine a bit....
This is the same truck ? from 1964 Ford F100 bad idle and Tranny
Old 02-27-2009, 02:34 AM   #3
silverhairdeere's Avatar
i would say yes and i would think fuel pump .
shd
Old 02-27-2009, 06:10 AM   #4
Time to rebuid the carb, accelerator pump sounds weak. you said you adjusted the carb back the screws out a turn you may have leaned it out to much
Old 02-27-2009, 08:00 AM   #5
did you happen to see the one crazymink posted in the classified? since you are into old fords
Old 02-27-2009, 02:29 PM   #6
uranium67's Avatar
Yea, im the one who had trouble with the transmission and carb
i have the 1964 f100
Old 03-08-2009, 06:30 PM   #7
fordson is on a distinguished road
hey i second the accelator pump in carb but also check for vacum leak
fordson is offline   Reply With Quote
Old 03-09-2009, 08:20 PM   #8
uranium67's Avatar
I rebuilt the carburetor and it seems to run better, but does anyone know what the Rear Band Adjustment is for the transmission?
I "THINK", emphasis on think, that that's the reason why shifting is slipping
Old 03-09-2009, 08:31 PM   #9
not good with fords, but i believe the band is only used in second and reverse gear. if it happens in all gears then i would look at fluid pressure. does that trans have a vacuum modulator? could be causing the engine issues also.
i'd rather be hunting
Old 03-09-2009, 08:35 PM   #10
uranium67's Avatar
Alright, cause when i shift the lever with the engine off, it slips in and out of gear, but when its going it shifts OK but the truck lurches forward, mainly in reverse.
Tags
carb
Dies intermintely. resonator Ford Truck Forum 3 01-28-2009 08:51 PM
92 gmc dies when put into gear kjack GMC Truck Forum 1 12-07-2008 08:13 AM
99 gmc 4.3L dies for no reason maeziesdad GMC Truck Forum 9 08-08-2008 10:37 AM
Dies when driving - help please!! thamick7 Chevy Truck Forum 14 05-30-2008 12:04 AM
truck dies... hillbilly Chevy Truck Forum 1 09-11-2005 12:50 PM
