Old 03-06-2009, 11:07 AM   #1
vinniepro's Avatar
vinniepro is on a distinguished road
steering wheel bounces and shakes?
i have a 1995 f-150. the steering wheel is real loose and it bounces around, when ever i turn the wheel it makes a spring stretching noise. at random the wheel will lock up and wont move unless i shake the wheel. does anyone have any idea what is wrong?
vinniepro is offline   Reply With Quote
Old 03-06-2009, 12:01 PM   #2
I know that on GM trucks some parts will wear under the steering wheel I would say just remove the wheel and see whats going on or buy a Chilton's manual or wait for a true ford fan to log on like 75K30 he knows a lot about fords.
Old 03-06-2009, 01:28 PM   #3
Sounds like the upper column bearing is bad. Like gmc says you will have to pull the steering wheel to confirm.
Old 03-06-2009, 08:11 PM   #4
i have a simple solution for this as i have done a couple with this same problem. go to the yard and buy a steering column for less than a c note. remove and install the one you just bought. replace the lock cylinders so that you keep the same keys and your problem is fixed.
Old 03-08-2009, 12:16 PM   #5
vinniepro's Avatar
thats a good idea but the problem i have is i can not get the wheel off because the air bag is in the way. is there a trick to remove it and not have it blow up on me?
Old 03-08-2009, 01:37 PM   #6
disconnect the battery and short out the cigarette lighter i believe. this will ensure that the bag will not deploy nor will you have a charge built up in the system capable of doing the same. as for disassembly, do a search on here as there was a post concerning this a little while back ago.
Tags
steering
Steering wheel. gmctrucks GMC Truck Forum 1 12-22-2008 03:25 PM
Steering Wheel Rattle chev08521 Chevy Truck Forum 3 03-29-2008 07:59 PM
Steering wheel rednekracer Chevy Truck Forum 4 03-05-2007 10:12 AM
Steering wheel removal Mike@Appliancep Chevy Truck Forum 0 08-18-2006 08:30 PM
How to get my steering wheel off ? Madman Mark Ford Truck Forum 1 12-21-2005 10:33 AM
