Old 03-10-2009, 09:29 AM   #1
RK01 is on a distinguished road
Slip Yoke Issues
Folks...appears that I may have the infamous slip yoke issue with my 99 F250 Super Duty 2wheel drive. Pretty straight forward fix...BUT what about the grease or lube?? I was just going to use what I had on the shelf which was some standard wheel bearing grease...pull it all apart.. give it a good going over and re-assemble. IS there a special grease to use?? and do I pack the boot as well?? any tips...or extras..please let me know...will attack it this weekend.
Thanks JDB
RK01 is offline   Reply With Quote
Old 03-10-2009, 09:52 AM   #2
Generally what ever you grease your chassis with is fine, wheel bearing will work, good luck
Old 03-10-2009, 10:48 AM   #3
You do not want to pack the boot. This is a slip yoke and not a CV joint. Over greasing the joint will only cause the grearse to squeeze out when the shaft compresses.
Use just enough to lube the splines and you should be just fine.
Tags
slip yoke
Limited Slip Questions blackhawk17 GMC Truck Forum 5 07-26-2008 01:00 PM
98 K1500 steering slip Mike450r Chevy Truck Forum 1 05-21-2008 09:19 AM
Driveshaft Transmission Yoke dstrick32 Ford Truck Forum 0 01-13-2007 09:37 AM
Repack Slip Yoke GM For Life GMC Truck Forum 2 01-06-2007 11:54 PM
trans slip? ramdodge Dodge Truck Forum 3 11-07-2006 01:39 PM
