Old 03-27-2009, 11:03 AM   #1
davey300 is on a distinguished road
ac compressor noise?
i have a 98 f-150 4.6 auto, i have been hearing a loud noise sounds like the ac compressor, if it is low on oil will it make like a loud howling sound? it only lastes maybe a minute. it is still blowing cold air also, anyway to check it? thanks dave
davey300 is offline   Reply With Quote
Old 03-27-2009, 11:42 AM   #2
if it was low on oil, you would have no freon and it would not be cooling assuming that this compressor is fairly old. does this noise happen at any given time, when cold, when warm??
Old 03-27-2009, 12:00 PM   #3
when it sits for a while, cold. the idler wheel sounds ok,alt,water pump. the sound is comming from the bottom around the ac compressor. thankd dave
Old 03-27-2009, 12:04 PM   #4
Are you sure it is not the belt tensioner pulley?
Sorry posted at the same time.
Case 7230 is online now   Reply With Quote
Old 03-27-2009, 12:11 PM   #5
eponator's Avatar
Double check those pulleys!
These sounds can be misleading and its as simple as removing the belt and rotating the pulleys by hand to determine if the bearings are still good or not.
Sometimes tightening the clutch bolts on the AC a little helps to make the sound dissapear but this is only a temp fix. If the A/C bearings or clutch are giving out its only a matter of time before the sound comes back and its worse than before!
Is the A/C or heater on when this sound presents itself or is it just on every cold startup regardless? Could also be the fan clutch, when they start to go they make a howling sound on cold startup too.
'99 F350 5.4L crewcab Longbed
Old 03-27-2009, 04:08 PM   #6
use a piece of pvc pipe as a listening tool and find where it is coming from
Old 03-27-2009, 05:19 PM   #7
hotrodpc's Avatar
Leo borrows my redneck technology to listen for noises too? I knew I should have pattened that idea when I got it. I also use a sawed off wooden broom stick or a large 2ft long, thick screwdriver I have. Point is Dave, the noise will play tricks on you and be coming from somewhere you don't think it is, so you can isolate the noise by using a pvc pipe, broom stick whatever, and put it on the housing of each accessory ran by the belt, close to the front, and put your ear to whatever you are using and listen for bearing grinding or thumps. If you find it, you will know it right away.
Old 03-27-2009, 06:12 PM   #8
thanks so much for the help!! i appreciate it alot!!
dave
Old 03-27-2009, 07:16 PM   #9
just be mindful where you put your stick while the engine is running. on every fan belt box, there is a caution sticker warning everyone to turn off engine before installation. no lie.
Old 03-27-2009, 07:21 PM   #10
hotrodpc's Avatar
Sounds like something my dad told me long long ago..... But on a serious note, great tip. It would be a serious injury if you goofed.
Replacing AC Compressor likofloathe GMC Truck Forum 2 12-21-2008 04:05 PM
AC compressor not engaging cplnorton Chevy Truck Forum 2 06-05-2008 06:02 AM
AC Compressor problem gerryl98 Chevy Truck Forum 13 12-15-2007 08:18 PM
AC compressor noisy jktuck Chevy Truck Forum 4 05-14-2007 02:48 PM
A/C Compressor Installation help!!!??? 4x4s1088 Chevy Truck Forum 2 08-08-2006 04:21 PM
