Old 04-03-2009, 01:51 PM   #1
schaff42 is on a distinguished road
whobble sound and feeling when accelerating
Originally Posted by 75K30
Originally Posted by schaff42
? When I excelerate my truck I am hearing a whobble sound. Only on exceleration. All tires are tight. I lift and check all four of them. Drive shafts feel tight also. What could it be?
Is this in a truck with a two piece driveshaft? YOu may have a center support bearing that is bad, or you could have a bad bearing in the transmission. Difficult to troubleshoot over a keyboard. Maybe a little more information.
DOnt be afraid to post a new thread so you can benifit from many ideas.
Try to be as specific as possible. Year, make, model, and equipment will be a plus.
75
2004 F350 6.0 crewcab srw. 8 inch lift 983 Kumho 365/22.5. Two piece drive shaft with bearing carrier. everything is tight when truck is on ground. I lifted the rear axle up off the grond and the u-joint is tight but the flange after the u-joint that connects to the pinion housing moves side to side when I push on it. pinion bearing or what ?????????????
schaff42 is offline   Reply With Quote
Old 04-04-2009, 11:07 AM   #2
you should have no movement side to side and only roughly 1/2 inch rotational play in the driveshaft which is normal ring and pinion backlash... side to side movement means your pinion bearings are shot....
Old 04-04-2009, 09:32 PM   #3
Would that involve a complete break down of the ring and pinion assembly to replace the bearings???
Thanks.
Old 04-05-2009, 02:18 AM   #4
hotrodpc's Avatar
It certainly would. I am not familiar with what rear end is in that vehicle. Some are easier than others if you want to do a patch job. If it were me, I'd just buy a bearing and seal kit and go through the whole thing if you are getting that deep into it.
Old 04-05-2009, 08:40 AM   #5
Generally speaking when a pinion gets that loose the depth is thrown off on your pinion and sets up an adverse wear pattern on the ring and pinion. Replacing the bearings will eliminate the play but most likely you will end up with a howl from the gear set. I would do a complete overhaul including new ring and pinion.
Old 04-05-2009, 09:05 AM   #6
stumpuller454's Avatar
Your probly have a sterling 10.5" I have rebuilt a many of those units, you will need a bearing puller set, a shop press, and a collection of carrier shims (possibly), and gear marking compound. If you haven`t done a rear end before however, i would probly recommend finding a buddy who has (just for precedure and setup) A good shop should be able to rerbuild one of those, and be in-and-out of the shop in a day.
Another thing I found common on these HD fords is finding that the u-joints seize regularily, showing no play and only half the time making noise before they fail (weird i know) so when your doing the rear end make sure you pull the shafts right out and feel the movment of the u-joints.
Old 04-05-2009, 12:42 PM   #7
Thanks for all the feed back. Pulled cover this morning and found a boken tooth on the ring gear. I assuming that the loose pinion/companion flange was the cause. I do remember a clunk sound when backing up the other day but did not put 2 and 2 together. So its off to Heavey metal performance in Rockdale IL. Running 4.56 with 41's.
Old 04-08-2009, 09:34 PM   #8
pics of broken tooth on ring gear
Old 04-09-2009, 07:08 AM   #9
It's a FORD. Just kidding.
Good luck! GMC
Old 04-11-2009, 08:51 AM   #10
Gear is in. Yukon 4.56 mith complete master bearing kit. So far so good. This was my first gear install. Will update.
Tags
differential, rear end
1998 Mazda B2500 truck makes a squeaking sound when accelerating, even in neutral Linda777 Mazda Truck Forum 10 12-19-2008 12:46 PM
engine bucks when accelerating swamphunter Chevy Truck Forum 4 07-07-2008 03:05 PM
Truck leader Carter feeling lucky after second Motorplex win (Tennessean) trucknews Truck News (headlines) 0 05-14-2005 03:30 AM
03/22/05 - East Texas Truck Drivers Feeling Gas Prices (KTRE-TV East Texas) trucknews Truck News (headlines) 0 03-22-2005 05:30 PM
How do i get the best sound? F150on40's Ford Truck Forum 4 11-08-2004 09:53 AM
