| In desperate need of help with cross referencing some parts and numbers. I have a 1997 D60 out of a F350 that is going in my 1995 F350. The only issue I have to deal with is converting it to a DRW front end. I want hubs that are a direct bolt on and will not require cross referencing when I go to buy bearings, seals and what ever else I will need. Now here is the question. I have a set of dually hubs that have been in my way for years. I was told they came off a 1979 F350 dually with a D60 front end. I have my doubts about that because I do no think Ford made one in 79. I want to know if these are the hubs I need, but they have different numbers on them. My wife measured everything she could and they are the same. Here are the numbers: First hub Budd 105427 2H11 WF-2 Second hub Budd (C) Maybe instead of a 0 105427 2009 WF-1 Does that mean one is left side and one right? Will they be the direct bolt on I am looking for. This is the last issue I have to have resolved before I go home on R&R
| I dont find those numbers anywhere, but you should know that a 79 dually was not available for a ford application. That being said, the spindle is the same from the early trucks to the later trucks. Only the TTB axle had a funky spindle, but even this could be used after a little grinding. Not that this matters, but according to Dana, the bearings are the same. I dont see why these will not work for your application. I understand and appreciate your limited time, and the importance of making this swap as pain free as possible, so I will try to dig around a little and see if we can identify these parts. 75 |
| Thanks man. I did not think Ford made a F350 four wheel drive dually. But With out researching it I did not want to argue with the guy. If they will work, it will save me a lot of time and money.
| engine numbers | lost in wyoming | Ford Truck Forum | 1 | 04-30-2009 02:26 PM |
| gas mileage numbers | carter442 | Chevy Truck Forum | 4 | 01-15-2009 07:04 PM |
| parts cross over? | ragnar | GMC Truck Forum | 0 | 11-04-2007 09:13 PM |
| Truck numbers drop, study says (Canoe) | trucknews | Truck News (headlines) | 0 | 05-14-2005 01:30 AM |
| Cross Lander Receives EPA Certification of its 4x4 Sport Recreational Vehicle; Cross Lander 244X Set to Make its U.S. (The Auto Channel) | trucknews | Truck News (headlines) | 0 | 12-21-2004 11:30 PM |
