Old 06-23-2009, 05:24 AM   #1
cburcham73 has a spectacular aura aboutcburcham73 has a spectacular aura about
strange miss at 1500 rpm
93 bronco,5.0,e4od. ive been tracing this miss for 6 months.the trucks seems to hesitate,stumble at 1500-1800 rpm.only at that rpm.doesnt matter the speed,or gear im in. i had a burnt #8 valve,replaced with new heads and still have the miss. new cap,plugs, wires,checked all the sensors,tps,map,iac,iat. runs smooth before 1500,then slight stumble and after 1800 perfect,new fpr,good pressure. im stumped.
cburcham73 is offline   Reply With Quote
Old 06-23-2009, 11:42 AM   #2
Banned
merlin5577 is a splendid one to beholdmerlin5577 is a splendid one to beholdmerlin5577 is a splendid one to beholdmerlin5577 is a splendid one to beholdmerlin5577 is a splendid one to beholdmerlin5577 is a splendid one to behold
Does the truck have an EGR valve? If so pull it off and check it for carbon build up. Sticking EGR valves can cause the problem your describing.
merlin5577 is offline   Reply With Quote
Old 06-24-2009, 09:28 PM   #3
i'll yank it off tomorrow. i know when i take off slowly and then let off the gas real quick it will stall.
Old 06-25-2009, 12:11 AM   #4
I agree.... You might take it off and put a piece of duct tape over the intake port and take it for a short spin.
Old 06-28-2009, 04:33 PM   #5
tested the egr,and blocked it off. to dice..could it be smog pump related. i heard of those things making the truck do weird stuff.
sporadic miss rpp GMC Truck Forum 4 04-20-2009 02:04 PM
Skip, miss, cut-out Flowtech1ton GMC Truck Forum 6 10-16-2008 07:37 AM
2001 miss dthompson Chevy Truck Forum 3 02-20-2007 09:53 PM
Miss or hesitation? spacoli Toyota Truck Forum 4 01-07-2007 12:10 AM
2000 silverado 1500 5.3 "miss" at idle WDDOBLER Chevy Truck Forum 7 02-02-2006 06:44 PM
