Results 1 to 5 of 5
Thread: 2004 Ford Ranger Battery Light on
    ADK is offline
    Jul 2009
    Question 2004 Ford Ranger Battery Light on
    I have a 2004 Ford Ranger 4.0L that the battery light started flickering and then came on all the time. Replaced the battery with no chage. Had the alternator tested at Auto Zone, two tests passed as good. Checking for loose connections now, serpentine belt is tight and looks good. Any ideas?
    crabtruck's Avatar
    Jul 2007
    Welcome to the forum ADK.
    That's not southern for IDK I hope.
    Have you checked the batt voltage when the truck is off,
    and what it is when truck is running ?
    Could be good compoments but not connected well,
    loose or damaged connections. That "charge" light
    is really a voltage light, so numbers would be helpful.
    Senior Member chickenbone's Avatar
    Mar 2009
    South Jersey
    Sometimes those ranger's, you have to reset the computer after a bad code from battery. Also if you changed the battery, do yourself a favor. Put new cable ends on. Best if you can crimp them on. The negative on those Trucks has to be 100%
    Ford puts cheap ends on to last about 4 -5 years. They get nasty on the inside of cable ends and you can't see it.
    Senior Member tjzz4's Avatar
    Oct 2007
    Sounds like an alternator going south... pretty common.
    Jul 2009
    Agreed. Could be alternator. Could be battery terminal cables.
  1. Battery light question
    By shaman683 in forum Chevy Truck Forum
    Last Post: 01-19-2010, 11:31 PM
  2. Colorado Battery Light
    By racin in forum Chevy Truck Forum
    Last Post: 01-19-2009, 02:37 PM
  3. SD Battery Light
    By paul turner in forum Ford Truck Forum
    Last Post: 01-03-2008, 01:43 AM
  4. 2004 Ford Ranger Fx4 Level 2
    By nkrummen in forum Truck Classifieds
    Last Post: 04-19-2007, 12:37 PM
  5. Replies: 0
    Last Post: 10-29-2004, 12:30 AM
