Closed Thread Ford Truck Forum - Enthusiasts can discuss ford trucks, accessories, etc.
Old 07-30-2009, 02:42 PM   #1
460dually is on a distinguished road
351 with hole in enigne
any ideals how this happened??????is it fixable? and is it worth it?
460dually is offline
Old 07-30-2009, 02:51 PM   #2
This a 335 series or windsor?
Really does not matter I guess. Have you removed the dizzy? It would appear that the distributor gear was damaged by either a bad oil pump or the shaft failed and a foreign object went between the cam / dizzy gear.
Perhaps the can walked that far? Any other damage? Have you pulled the cam?
75K30 is offline
Old 07-30-2009, 02:55 PM   #3
havent pulled nothing else wanted to know if it was worth it first? and its a windsor
Old 07-30-2009, 04:48 PM   #4
does anybody know if it can be fixed?
Old 07-30-2009, 04:51 PM   #5
BernieB's Avatar
Hard to say, just looking from the outside.
BernieB is offline
Old 07-30-2009, 06:12 PM   #6
It looks like a sandhole in the cast. Why did you pull it down? it could be welded or drilled tapped and plugged. If it is not affecting anything it's fine, but you could plug it with jb-weld if it bothers you
leolkfrm is offline
Old 07-31-2009, 09:19 AM   #7
well it started making some really loud clanking noises and the oil was way over filled with either gas or water im not sure the oil isnt milky.but yea a sand hole? could it cause fluids to mix?
Old 07-31-2009, 11:04 AM   #8
Nope most it would do is let oil from the top go into the crankcase....if the oil is not milky then gas or other oil is suspect. what does it smell like?
leolkfrm is offline
Old 07-31-2009, 11:29 AM   #9
lol smells like oil just really thin, when i drained it there was about twice what should be in there
Old 07-31-2009, 11:37 AM   #10
It has gas in it. Ford pumps are known for a leaking diaghram and the leak allows fuel to enter the engine. Once the engine filled with fuel the oil thinned out and the already poor oiling system could not keep the bearings functional. Thats where the noise came from.
It is still possible that the thin oil caused the oil pump to fail, and the pump siezed up sending the shaft up into the dizzy and the dizzy is busted (at least the gear is) and busted the block.
While this could be a sand casting imperfetion, this will eventually crack, if it is not already, and turn into problems.
Taking the dizzy out if you can and removing the pan will tell you the rest of the story.
75K30 is offline
Closed Thread
WTB 16" 6 hole gm wheel Sneakysportsman Truck Classifieds 3 02-25-2009 07:31 PM
Drilling hole in the firewall... Mikes96Z71 Chevy Truck Forum 5 01-24-2009 12:21 AM
weep hole adrnmrnda Chevy Truck Forum 3 06-01-2008 06:48 PM
HELP-pin hole in gas tank tims84k10 Chevy Truck Forum 1 11-13-2007 10:47 PM
Hole in the hood. How can i patch it up? bubbas91lariat Ford Truck Forum 12 07-21-2007 02:48 PM
