| door stop problems hey ive got a 98 f-150 and the door stop cracked in half when i pulled in the parking lot today i just then broke the rest of it off so it wouldnt destroy the door, to replace do i just need the part and bolt it on the door then push it through the two ball bearings? or is there a piece behind that? or do i need to take it to a profesional? thanks for the help |
| Door stop? Can you explain a little better? Which door?
| yea sry its the piece midway down on the inside of the door next to the front quarter panel and it keeps ur door from swinging around and or closing on u its bolted to the door and leads well in my case lead into the front quarter panel, if u kno the technical name for it plz let me kno so i dont have to sound like such an idiot haha, in my haynes repair manual though it says its called "door stop" |
| also its the driver side door |
| Full Member Join Date: Jul 2009 Location: benton ky
| striker plate?
__________________ it takes one ball for most sports thats why i like drag racing |
| Senior Member Join Date: Nov 2008 Location: upstate S.C.
| i think he means the little notched lever that holds the door open on a small incline. it also keeps the door from swinging too far and damaging the fender. i don know what you call it tho. its located between the upper and lower door hinges on chevrolets, i assume its the same for fords. i would think it would just unbolt and come out, but im not sure, never had to replace one. |
| | #7 | |
| i believe they sell this as a whole part but have been proven wrong before. trick is that the plate there that it bolts to is behind the sheetmetal. it moves around a bit and have heard of this plate falling down when the last bolt is taken out. this has also happened to me when replacing the hinges. |
| | #9 | |
| yea it is the part between the hinges bt thanks for the advice im going to the junkyard tommorw to try and get and one from a clunker they dont have it at auto zone, hopefully itll b easy enough to get out and then reinstall, thanks for the advice yall |
| please help me stop | jrandalls | Ford Truck Forum | 6 | 05-09-2007 01:49 PM |
| Door Problems | Farm Boy | Chevy Truck Forum | 11 | 09-28-2006 10:32 PM |
| F350 diesel door ajar light problems | be4969 | Introductions | 2 | 05-24-2006 02:06 PM |
| I know how to make your door stop dinging if you have a 96 or older f150 | bubbas91lariat | Ford Truck Forum | 0 | 12-31-2005 04:37 PM |
| power door unlock problems | chris ss | Chevy Truck Forum | 1 | 12-23-2004 10:39 PM |
