Old 08-19-2009, 05:53 PM   #1
Steve g.'s Avatar
Steve g. has a spectacular aura aboutSteve g. has a spectacular aura about
Thumbs down 1998 Ford Ranger won't start in Park
As stated, the truck won't start while it's in Park - have to put it in neutral to start it.
Anybody else have this problem?
It started gradually a few weeks ago, it would also not fully engage sometimes when shifted into drive (this started before having to start it in neutral)
Does it sound like a linkage problem?
I haven't looked into it yet since I don't have time but will once I get some feedback.
Thanks,
Steve
Steve g. is offline   Reply With Quote
Old 08-19-2009, 06:14 PM   #2
Kennyray's Avatar
Kennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to beholdKennyray is a splendid one to behold
could be a linkage problem, if it is out of adjustment range selector switch may not be reconizing it as being in park
On a quiet night you can hear a Ford rust
Kennyray is offline   Reply With Quote
Old 08-20-2009, 02:14 PM   #3
Towtruck's Avatar
Towtruck has a spectacular aura aboutTowtruck has a spectacular aura about
The Nuetral Safety swith might be bad. the points inside could have finally just wore out in the park position.
Towtruck is offline   Reply With Quote
Old 08-20-2009, 04:31 PM   #4
Steve g.'s Avatar
Please explain
Old 08-20-2009, 08:43 PM   #5
BernieB's Avatar
I'd be inclined to suspect a linkage problem, due to the "not fully engage" issue. IIRC those trucks had nylon inserts at the pivot points on the linkage. Those inserts sometimes broke or wore out, leading to a lot of play in the linkage. Easy fix though, as the replacements snap right in.
Old 08-21-2009, 04:49 AM   #6
Steve g.'s Avatar
So how should I go about fixing the inserts? Where can I find them?
Old 08-21-2009, 10:54 AM   #7
BernieB's Avatar
Pop the hood and start looking at the linkage. Follow it down under the truck and look at every place there's a connection. Check each to see if it's loose. They should move easily, but not have any "slop" in the connections.
Old 08-29-2009, 01:19 PM   #8
Steve g.'s Avatar
I can't see the linkage from under the hood or even from under the dash, what should I be looking for? A wire, a metal piece?
Old 08-29-2009, 01:30 PM   #9
Steve g.'s Avatar
It won't shift into 1st gear, it won't start in park... only in nuetral. When I just started it just now, it wouldn't drive forward in D or 2nd gear. But it will drive in Reverse perfectly fine.
still need to find the linkage....
Old 08-29-2009, 02:49 PM   #10
Steve g.'s Avatar
problem fixed, it was a loose screw coming from the gear shifter bracket.
looking at ford ranger buckinghorse Ford Truck Forum 8 06-19-2009 10:45 AM
1998 ford 9000 batty1214 Other Trucks 24 04-11-2009 08:22 PM
1998 Chevy Z71 will not start swflatt Chevy Truck Forum 1 05-26-2008 05:47 PM
1998 Dodge Dakot wont start rlandryjr Dodge Truck Forum 8 04-14-2008 04:28 PM
1998 Ford F150 XLT review (Carsurvey.org) trucknews Truck News (headlines) 0 07-20-2004 07:30 PM
