Old 08-21-2009, 03:01 PM   #1
cmeg1139gman is on a distinguished road
axel swap
I am looking at converting my 1985 f150 to a straight axel found a set of 1975 f250 highboy axels dana 44 front and a dana 60 rear was woundering about info on these axels ?
cmeg1139gman is offline   Reply With Quote
Old 08-21-2009, 05:12 PM   #2
FOURX4TRUX has a spectacular aura aboutFOURX4TRUX has a spectacular aura about
I would steer clear of the high boy stuff, I dont know how the high boys got there good name but there actually quite junk, low pinion, big hub, hard to find parts for. you need to find a like a 78 or 79 half ton ford. that way you can stay with coil spring and the conversion stays a lot simpler. you just move the radius arm mounts back a little and fab a track bar bracket, the rest is pretty much a bolt together swap. if ya need pics i can give them to. hope this helps.
FOURX4TRUX is offline   Reply With Quote
Old 08-22-2009, 12:23 PM   #3
thanks for the information looked at a 1978 front end will be a lot easier to convert over
Old 08-22-2009, 05:48 PM   #4
Lonesome7.3's Avatar
Lonesome7.3 is a jewel in the roughLonesome7.3 is a jewel in the roughLonesome7.3 is a jewel in the roughLonesome7.3 is a jewel in the rough
The big hub D44 is very tough to find parts for. My question is whay do you want to convert to a straight axle? With a little work a TTB can be a **** fine front end.
I got the **** lights off of an abandoned truck in Iraq.
Old 08-28-2009, 01:29 PM   #5
do some mudding an the axle housing always pack full of mud so usally have tro pull axels out to clean mud out .
I have no complaints about it put a EZ lock in it and it showed up a couple trucks at last mud pit went to
Old 08-28-2009, 01:47 PM   #6
I never had that problem when I took mine into the mud.
98 S10 Where is rear axel fluid fill hole ? STRAYDOG Chevy Truck Forum 8 10-14-2008 12:42 PM
info needed on soild axel swap pscheers Chevy Truck Forum 5 10-10-2007 05:20 PM
1994 Silverado 1500.....axel spline 28 or 30? Dennis Chevy Truck Forum 1 07-17-2007 01:21 PM
Axel manufacturer to close plant in Statesville (The Charlotte Observer) trucknews Truck News (headlines) 0 12-21-2004 01:30 AM
