| Senior Member Join Date: Aug 2009 Location: Ft.liqourdale, FL.
| Wierd Engine noise I have a 1995 Ford F-150 5.8L 4x4 with 222,000 miles on it. I can rev up the engine in park or nuetral and it sounds like it should. When i take it down the highway and press down on the pedal it makes this loud rattling noise that sounds like its coming from the engine. i can't figure this one out. Any Ideas?
__________________ ASHES TO ASHES, DUST TO DUST, IF IT WEREN'T FOR CHEVY'S MY TOOLS WOULD RUST |
| i really need someones opinion on this one the noise is really starting the **** out of me.
| From your description it could be bad rod bearings, however you would expect to hear them if reved from cold in Park. If it`s more a rapid pinging sound it could be pre-ignition. A higher octane gas may cure that. It could also be a cracked flex-plate or loose torque converter bolts or loose flex-plate to crank bolts. If some of these the starter may be noiser that before. Just my opinion, hopefully someone else will have some ideas. |
| I'll check those out. One thing is i noticed it started doing it after i changed the timing chain. Maybe it needs to timed mor acuratly?
| rattling sounds like exhaust problems such as a leak or possibly the inside of a cat coming apart. |
| I`d also say flexplate cracked.... put it in drive and attempt to do a brake stand, before you start your tires rolling see if you can hear the same noise... just an idea
| I'm going to go against popular opinion here and say your timing is off and you're getting preignition. Any chance you skipped a link putting in that chain?
| i'm with bernie!, it started after you had it apart, why did you pull it apart? had it jumped time?
| well when i got the truck it was running a little rough so i changed it thinking it had alot of miles on so i replaced everything chain and gear set, water pump, radiator hoses, belt, did a full tune-up.it didn't skip time but someone had recently changed it and screwed up when they installed it. If i would have known that mechanic i would have reamed him out. I wasn't able to fine tune the timing because i didn't know where to unplug the ECM so that i could manually adjust it. I can brake stand and it won't do it either. i guess it might just be preignition. does anyone know where to unplug the diod for the ecm so i can manually adjust it?
| Full Member Join Date: Aug 2009 Location: FARMINGTON,MO
| The diode should be real close to the dist. ![]()
__________________ MYSPACE.COM/TDS |
| Tags |
| ford f150 |
| Weird noise passenger side engine bay | Ninja_Lawn_Guy | GMC Truck Forum | 11 | 07-09-2009 06:43 AM |
| Popping noise from pass. side engine | Ninja_Lawn_Guy | GMC Truck Forum | 5 | 08-22-2008 06:15 PM |
| wierd speedometer | greg687 | GMC Truck Forum | 5 | 06-14-2008 11:46 AM |
| wierd sighting | mudseeker | Other Trucks | 17 | 12-13-2007 05:40 PM |
| 97 Mazda engine noise?? | jmmtsu | Mazda Truck Forum | 5 | 08-21-2006 02:55 PM |
