| Full Member Join Date: May 2007
| 1981 F100 Keeps running My son has a 1981 V6 (I think 4.9) and it would not run at all. He changed the spark plugs, plug wires, distributor and started the truck. He drove it down the road and when he came back home it would not stop running. I think it is carbon build up but did not have any carburetor cleaner (I will get some tomorrow) what would cause the truck to continue to run even after we turn the ignition switch off? We even pulled the spark plug wires off and it still ran. We had to put a shirt over the carburetor to get it to stop Help please! |
| run a can of seafoam through a tank of gas. and change the ff after, if its a cheap ff change it prior to seafoam, then change it after the tank. must be a ton of buildup in there,another trick i`ve heard of is to get the engine hot, rev it up to about 3k rpm and then proced to spray water down the carb (from a spray bottle) the water will enter the hot combustion chamber and expand very rapidly blasting the carbon off of everything, again i heard this works but have never tried it. my dad said he used to do it once or twice a year to his old 79 chevy truck.
| I've done the water spray myself on badly carboned up engines, and it does work beautifully.
| i used to add ice to the bottle, the colder the water the better the job. Delco used to make a chamber cleaner which worked well but i don't know if seafoam is the same thing
| Did you fit the correct spark plugs? Did you check the ignition timing? |
| Thanks I will try the seaform and water and see if it does the trick. I do have the right spark plugs, cap and ignition timing is good Last edited by larbec7; 08-27-2009 at 03:26 AM. Reason: want to get automatic email |
| major contributor to carboned up engines >>> dirty air filters. |
| 66 f100 | crazymink | Truck Classifieds | 33 | 08-10-2009 08:31 AM |
| 1954 f100.......... | midewkett | Ford Truck Forum | 1 | 07-02-2009 06:05 PM |
| 1978 ford f100 value?? | fordcrazy | Ford Truck Forum | 10 | 09-15-2008 08:53 AM |
| 1983 F100 2wd | kywanderer | Ford Truck Forum | 1 | 06-04-2007 12:17 PM |
| 1983 Ford F100 flareside | okie | Ford Truck Forum | 1 | 01-15-2005 10:36 PM |
