| Full Member Join Date: Dec 2006
| Changing out the anti freze 1999 F-250 Super Duty, 7.5 Turbo Diesel, Extended cab, Auto tranny. Amazingly I have pulled a 12,000 lb trailer for 3 years now and the engine has never even come close to overheating even on the worst of grades. Just the Fan clutch kicks in now and then. I couldn't ask for a better cooling system. But I do believe that I better change the anti freeze out and was somewhat amazed to find that there is no radiator cap, at least not that I could see. I see where I can drain the system by removing the lower radiator hose. But am stumped at how to go about refilling the system. Hopefully I am just overlooking some minor detail. Or should I leave this job up to the pro's? BTW, are there any thoughts about the so called "Permanent Anti Freeze" that supposedly never needs changing? |
| | #2 | |
| no you need to change the anti freeze. although there is no "radiator" cap you will have to remove the degas bottle cap and fill through there. This info was taken from a specialty site pertaining to what coolant to use. You need to use a coolant designed for the rigors and abuse of diesel engines Quote:
__________________ John Wayne 2000 F-350 7.3L Powerstroke 4x4 | |
| Full Member Join Date: Oct 2008
| Thanks for the information! |
| mrjohnwayne, Thanks for the info. And though you say there is no need to change the anti freeze, doesn't the anti freeze lose its rust innhibitors and water pump lubricant over a period of time? However, would it be right in assuming that since the system is sealed, there should be no loss of rust inhibitors/water pump lubricant? And since I purchased the truck used I can only assume that the green anti freeze (That is still clean in the recovery bottle) is Prestone? |
| Sorry if if sounded that way but I said you DO need to change the anti-freeze. It is just like everything else after time it will wear out and become less efficient etc... Being a 99 it could have came with green antifreeze from ford either with an added sca and a pre mixed solution. It just depends on the date of manufacture. My 2002 had gold anti freeze, but my 2000 I have now came with green as did most early 99's etc... I'm not sure what year they changed to gold, but as stated above sometimes color isn't a good inspection of what may be in there.
| | #6 | |
| Some additional info that may help in selecting the right coolant for your diesel is the ASTM number. This excerpt from a longer article gives that info: Quote:
| I did some additional checking and found that Prestone makes a Heavy Duty Extended Life Coolant (both in full strength and 50/50) that Autozone is listed as carrying (according to Prestone) and which meets ASTM D-6210. Checked the Autozone site and couldn't find it but I'm betting you could order it, or check any good truck stop like Flying J, TA, or Pilot
| Wow the plot thickens, I think I will take it to the Ford dealer and let them do it. And yes mrjohnwayne I did misread your opening statement. OOps!!! And thanks for the input from both you and BernieB. |
| Tags |
| anti-freeze, diesel coolant |
| Well had another anti freeze leak | partsman | GMC Truck Forum | 5 | 07-04-2009 10:42 AM |
| Anti freeze seeping out? | partsman | GMC Truck Forum | 25 | 05-13-2009 04:02 AM |
| What anti-freeze? | partsman | GMC Truck Forum | 10 | 03-02-2009 09:03 PM |
| anti spin differential | redneck 0991 | Dodge Truck Forum | 6 | 02-17-2009 11:29 PM |
| Anti or Pro Abortion? | Ford4x4Chik27 | Off-Topic | 12 | 01-14-2006 11:40 PM |
