| 1994 f-150 The truck has a 302 EFI. When you first start it, the idle comes up to 1500rpms, the check engine light flashes 3 times. Then the idle comes down to about 800. Then when you drive it, sometimes it hesitates and backfires through the air cleaner. I changed just about evrerything i can see.The truck runs fine after all of that, like it never happend. I've been chacen this for 3 years. Last edited by mader64; 10-07-2009 at 07:55 PM. |
| sounds like timing problem to me. the high idle is just the choke kicking on and off. backfire is indicative of timing issue. |
| Have you checked the trouble codes? Last edited by Case 7230; 10-08-2009 at 05:53 AM. Reason: typo |
| ivegot a 300ci 6cyl and a 5spd for sale if you wanna convert |
| Full Member Join Date: Oct 2009 Location: SAN PERLITA TEXAS
| Sounds like you might have a bad ECM - check the harness and terminals for corrosion. |
| 1994 Ford Van help | ErwinRommel | Ford Truck Forum | 1 | 06-15-2009 01:25 PM |
| 1994 kingkab | brad4eva | Chevy Truck Forum | 13 | 02-02-2009 02:56 AM |
| 1994 Suburban | Doktor Rocket | Truck Classifieds | 1 | 08-24-2008 12:37 PM |
| 1994 silverado | John1 | Chevy Truck Forum | 1 | 07-14-2007 09:16 AM |
| 1994 Gmc | joshnkelly | Introductions | 2 | 11-12-2006 11:50 AM |
