Old 10-12-2009, 12:16 PM   #1
Briefcase is on a distinguished road
1999 F250 super duty
Hey
I am new to the forum, and need help. My Truck is not shifting into gears. It stays in first gear. It's a V-10 automatic gas.
Briefcase is offline   Reply With Quote
Old 10-12-2009, 07:08 PM   #2
need some more info.. auto or manual, diesel or gas etc.. please help us help you.
Old 10-13-2009, 01:02 PM   #3
eponator's Avatar
Well you've got yourself the 4R100 Automatic Trans found in the earlier superduties. They are a little weak from the factory and are known to give out a little early in these trucks but with some mods they can be made to last.
As far as specifically what is wrong with it I have no clue, I'm still learning about transmissions but hopefully someone else can chime in with some more detailed info for you.
Good luck with the fix and don't let it get you down, these trucks are beasts once you've addressed the very few weak points (tranny included).
'99 F350 5.4L crewcab Longbed
Old 10-20-2009, 11:40 AM   #4
What scan tool can I use for a 1999 F250, V-10, gas, super duty?
Old 10-20-2009, 11:49 AM   #5
eponator's Avatar
If you're referring to the code readers to diagnose the check engine light then any standard obdII port code reader will do. Harbor Freight has them on sale every now and then. I forget how much but anywhere from $15-30 is normal.
If you need to diagnose ABS codes and the like then a full on scan tool will do. I don't know much about them but I've heard something about usually requiring additional software packets specifically for the superduties. Maybe someone else can chime in here...
1999 F250 Super Duty alarm problem mbarcher Ford Truck Forum 1 09-12-2009 01:05 AM
1999 F250 Super Duty DTC P1406 fatboyspur Ford Truck Forum 6 11-10-2008 09:41 PM
4 speed super duty trans. 07vmax GMC Truck Forum 6 07-20-2008 09:54 PM
200 ford f250 super duty heater problem vettford Ford Truck Forum 3 11-25-2007 02:24 PM
99 Super duty clpfiste Ford Truck Forum 3 03-14-2007 09:18 PM
