Old 10-16-2009, 08:54 PM   #1
Lenster is on a distinguished road
Bushings and ball joint
Hey..
Any suggestions as to should I need to change my entire front end bushings. Should i go with poly or oem? And if so which make? I also need ot change ball joints.. Any suggestions?? Thanks..
Lenster is offline   Reply With Quote
Old 10-17-2009, 03:02 AM   #2
I used poly for front sway bar and rear leaf spring bushes and very pleased with them so far. They were Energy Suspension bushes.
As for ball joints I would go with Moog.
Old 10-17-2009, 06:12 PM   #3
ditto to both, poly bushings will give you alot better ride and control etc.. just make sure you keep them lubed or they will squeek, and as for ball joints again Moog all the way! they are pricey but there is not a better ball joint out there and this is not one of the components you want to skimp on...
Old 10-18-2009, 03:46 PM   #4
Thanks guys.. Thats what I am planning on doing....
Old 10-19-2009, 12:45 PM   #5
1ATony is on a distinguished road
Yeap the MOOGS are nice ball joints.
1ATony is offline   Reply With Quote
Old 10-19-2009, 04:06 PM   #6
BernieB's Avatar
I've gotta chime in here and also say, MOOG would be my #1 choice for ball joints. Those guys build 'em to last.
ball joint help! see error GMC Truck Forum 14 11-27-2008 06:37 PM
Rubber ball joints/ bushings Ninja_Lawn_Guy GMC Truck Forum 3 08-14-2008 10:03 AM
Lower Ball Joint rednekracer Chevy Truck Forum 7 05-07-2007 09:03 PM
Lower ball joint???? LandSharkGT Nissan Truck Forum 10 12-26-2006 03:58 PM
Ball joint replacement vettman Chevy Truck Forum 3 08-20-2005 02:29 PM
