| 460 swap I have a 84 F350 with a 6.9 deisel with 4 speed trans.The motor is shot and I would like to put in a 460.Would the motor mounts work,would the trans work? Any help appriciated. |
| Banned Join Date: Jan 2009 Location: Southern Georgia
| Might have to get a different bellhousing. Motor mounts won't work I think. Might have to fab you up some. |
| Senior Member Join Date: Nov 2008 Location: West Covina, Ca
| Along with the bellhousing and motor mounts you'll also need a new set of guages... Diesel tach's don't run as high as gassers do etc... Might look into getting a dash from a gasser truck, that way you get rid of the wait to start lights and other diesel only indicators... unless you don't mind them just being there I'd say drop a 7.3 in em!! With a little bit of work they can put out good amounts of power and I think you could then re-use the motor mounts and the guages there as well.
__________________ '99 F350 5.4L crewcab Longbed |
| I think I might need to change the rear gears as well. |
| Senior Member Join Date: Apr 2009 Location: Florida
| Check with Advanced Adapters. They can adapt just about anything to just about anything. |
| I would go back with a 6.9. Rebiuld the old one if it can be rebuilt. Going with a 7.3 IDI would be less work that the 460 swap. Just about everything will bolt up. A friend of mine that did a the same swap you are talking about in an 85 F350 changed out the crossmember. I do not know why, it might have had to with his suspension plans. Why do you think you have to change the gears?
| | #7 | |
shd | |
| That I am. I guess there could be worse things to be...
| Well, for a while now. I am trying to get into the Police Academy which is a few miles down the road. Then I will have to work here locally for at least a year before I can get on with a federal agancy.
| 300 to 351 swap | caseih | Ford Truck Forum | 9 | 09-03-2009 10:46 AM |
| 4.3 to 5.7L swap | garybt3 | Chevy Truck Forum | 10 | 08-31-2009 08:33 AM |
| Cab Swap any Help | creepn06 | Chevy Truck Forum | 4 | 05-01-2009 06:22 PM |
| How to swap out a D50 for a D60 | Steve g. | Ford Truck Forum | 18 | 08-09-2008 02:57 PM |
| 6.2/5.7 swap | project88 | Chevy Truck Forum | 3 | 11-26-2007 11:04 AM |
