Old 10-21-2009, 10:43 AM   #1
deftones904's Avatar
deftones904 is on a distinguished road
Lightbulb huge trouble switching tanks
ok we have 2 89 ford f 250s and when 1 tank runs out we flip to the other and it will stall and not restart till we purge all the air out from under the hood out of the fuel lines. which takes like 5 mins. so is somewrong or do we never let the truck run out of fuel
1987 GMC Sierra Classic 1500 (350 throttle body injection) 1988 Izuzu Pickup (2.3L 2 barrel carb) R.I.P.
deftones904 is offline   Reply With Quote
Old 10-21-2009, 11:01 AM   #2
Never let it run out of fuel. Switch tanks before that.
Old 10-21-2009, 11:45 AM   #3
eponator's Avatar
Seriously, never let it run out of fuel... If ya see it get on E switch tanks then and there (or if your low fuel light goes on).
The system was not designed to work the way you are currently using it. Air in the lines is also hard on the injectors.
'99 F350 5.4L crewcab Longbed
Old 10-21-2009, 12:48 PM   #4
Crmzendrgone's Avatar
Agreed seems like a comment thing to switch before one tank is completely empty.
Old 10-21-2009, 05:59 PM   #5
crabtruck's Avatar
Letting the tanks go that low also is hard on filters/pipes/valves in fuel system
since it stirs more jumk that has settled out in tank. Encourages rust too.
Old 10-23-2009, 08:23 AM   #6
i understand all that but are u guys saying i can fix this. cause no way back in 1989 ford made a truck that when it runs out u have to do all that **** to get it going again. our older carb trucks have no issues doing that. none of the fuel gauges work in any of the trucks so we try not to but we do run out sometimes. plus if we fill them up likly to get some sucked out at night
Old 10-23-2009, 10:31 AM   #7
The problem is that with an IDI diesel when it runs out of fuel the system has nothing but air in it. When you switch tanks the lift pump starts pumping fuel from the good tank but because the air can only bleed slowly from the lines and the injector pump, the injector pump cannot fill with fuel. Until it fills with fuel it will not deliver any fuel to the injectors and hence to the combustion chambers. A long period of cranking on the starter will gradually bleed the air out through the injectors allowing the injector pump to fill with fuel and hence the engine will start.
There is no way around it, other than to not let it run out of fuel.
Old 10-23-2009, 11:15 AM   #8
eponator's Avatar
Case7230 pretty much summed it up right there. Carbed motors work differently than these guys, just gotta get used to it.
Old 10-23-2009, 11:34 AM   #9
repriming diesels are a pain. best way i have found is to bleed the lines up to the injectors. this is a good reason why you fill the filter up at every change before screwing it back on. otherwise, she acts like she will never start.
Old 10-23-2009, 03:19 PM   #10
crabtruck's Avatar
Missed the part where it said diesel ....??
dual gas tanks brucebowker GMC Truck Forum 5 09-08-2009 09:20 AM
Is switching out dashes between models too hard? youngdamage Chevy Truck Forum 6 08-17-2009 01:26 PM
2003 Sonoma 4X4 Crew Cab - 4WD switching issue. jpollman GMC Truck Forum 4 07-22-2009 02:18 AM
87 GMC ..AC keeps switching to heat. waywood GMC Truck Forum 1 06-27-2009 06:34 AM
dual tanks bigcountry78 Chevy Truck Forum 3 01-28-2009 02:13 PM
