| 1999 Ford Ranger won't run - codes listed Hello - it's a 1999 Ford Ranger 3.0 (4x) - it just wont start/run - just backfires...we think that it's getting too much gas...(?) Codes: PO0171 too lean bank 1 PO304 Cyl 4 misfire PO306 Cyl 6 misfire Fuel PSI between 50 & 70 So far we have checked for vacuum leaks etc and replaced the following: plugs and wires, crankshaft timing sensor (CKP), cam sensor (CMP), the timing chain, all oxygen sensors (O2s). mass air flow sensor (MAF) Not sure what to do next - appreciate any advice. |
| do a compression test on the cylinders, all of them. the tester is relatively cheap and might can be rented free from autozone. this might shed some light as to why it is 1. backfiring, 2. measuring too lean meaning too much air and not enough fuel, and 3. why just those 2 cylinders. |
| Hi - thank you for your response - we will do that compression test....do you have any idea why the code would indicate "too lean" however we could smell gas from the exhaust (before it quit running) and the spark plugs were soaked with gasoline when we replaced them. Again thanks for your help! |
| does it have a timing belt?
| It has a timing chain...and we replaced it - - it was not bad and the timing marks lined up correctly so it had not jumped a tooth or anything. |
| if you turn out with lower compression in those 2 cylinders, do measure all of them, than you likely have a bad couple of exhaust valves which would not get a good burn in the cylinder, hence the misfire, and combustion out of the cylinder which would be backfiring and possibly lean condition a it is also igniting unburnt gas leaving the exhaust manifold. anyone here think that sounds like BS?? ![]() |
| Welcome to the forum sox. You may want to disconnect battery for 10 min to force a re-learn for fuel. On a truck with MAF, no real baro info is available so it is calc'd and stored. You may be "holding" the rules for a problem you have already "fixed" |
| 1999 Ford Ranger problem | ErwinRommel | Ford Truck Forum | 2 | 07-06-2009 08:20 AM |
| 1999 Ford Ranger 2.5L problems | ErwinRommel | Ford Truck Forum | 14 | 05-21-2009 08:09 PM |
| How do you install a driver side window in a 1999 ford ranger? | ErwinRommel | Ford Truck Forum | 2 | 03-23-2009 10:03 AM |
| BUYING 1999 Ford Ranger Driverside Window | ErwinRommel | Truck Classifieds | 0 | 03-16-2009 08:13 PM |
| 1999 Ford Ranger XLT 4x4 Sport review (Carsurvey.org) | trucknews | Truck News (headlines) | 0 | 09-24-2004 05:30 AM |
