| 1998 ford expedition will not start I just purchased a 1998 ford expedition that thay say will crank but will not start. Thay said the battery is down and thay tryed to boost it but it would not hit. I dont realy know where to start first.Need help bad!!! |
| first thing I would check would be the inertia switch for the fuel pump. Not sure where it is located on the Excursion, possibly under a removable panel, on the drivers side in the back.
__________________ None of the secrets of success will work unless you do. |
| I will try that . Thanks very much |
| if cranks but does not start, then it is not a battery problem. after charging the battery, will it try to crank but not start?? |
| Full Member Join Date: Nov 2008 Location: Lapeer, Michigan
| charge or replace battery, turn key to run not start several times listen or have someone listen for a hum at the fuel tank. Gas engine? If no hum as the other guys said inertia switch, fuel pump relay, fuel in tank? Hopefully for you it hums then check fuel rail for presurized fuel, looks like a valve stem on a stainless steel rail, push it down taking all the precautions, saftey glasses, no open flames, maybe put a rag over the stem to absorb the fuel. If you have pressure good, still won't start, take the air filter snorkle off the throttle body open it manually, spray ether, WD-40 (5-10 second blast) crank engine it should fire, if not you have an electrical problem |
| Junior Member Join Date: Oct 2009 Location: Iowa
| Check in the owners manual for the location of the fuel pump shut off switch, most likely under the dash on the passenger side, that would be the cheapest fix |
| Thanks to every one I will let You all know what happin's. Thanks again |
| 1998 Ford Ranger won't start in Park | Steve g. | Ford Truck Forum | 9 | 08-29-2009 01:49 PM |
| 1998 ford 9000 | batty1214 | Other Trucks | 24 | 04-11-2009 07:22 PM |
| 1998 Chevy Z71 will not start | swflatt | Chevy Truck Forum | 1 | 05-26-2008 04:47 PM |
| 1998 Dodge Dakot wont start | rlandryjr | Dodge Truck Forum | 8 | 04-14-2008 03:28 PM |
| QCTimes.Com: Top Jobs: FORD '01 Expedition 4x4 XLT (Quad-City Times) | trucknews | Truck News (headlines) | 0 | 06-05-2005 06:30 PM |
