Old 11-11-2009, 08:52 AM   #1
msingleton is on a distinguished road
1989 E350 fuel sending unit
I have an E350 with a 460 ci engine and I need a replacement fuel sending unit. It' s for an RV with a 40 gal tank mounted behind the rear axle and includes a fuel pump and it has 3 outlets. I've tried the major parts outlets online but I could only find 2 outlet senders. Tried the RV places online as well with no luck and major chain parts stores. Any ideas where I can find one? Thanks in advance.
msingleton is offline   Reply With Quote
Old 11-11-2009, 11:14 AM   #2
Faxcion's Avatar
Faxcion will become famous soon enoughFaxcion will become famous soon enough
So your not looking for a fuel pump just a sending unit??
тнuмрıиg мч sкoаl cаи
Faxcion is offline   Reply With Quote
Old 11-11-2009, 03:16 PM   #3
Welcome to the forum msingleton.
It's somewhat rare for the sending unit to go out
instead of the pump. You've tested the sender itself ?
Many times the real problem is corrosion or broken wires.
Worth a look. Sorry I don't have a lead for you.
Old 11-14-2009, 05:50 AM   #4
Thanks for the welcome. Actually the whole unit is dead. All inputs to the unit read zero ohms regardless of which pins are measured. Got good voltage to the unit and the gauge works fine when jumpered at the tank connector so the wiring is okay. Also found very little corrosion on the connector. I haven't dropped the tank yet - still has ~30 gallons. Guess I'll pull it out and take a look since it's stored for the winter.
Old 11-14-2009, 02:03 PM   #5
A mis-type ? " All inputs to the unit read zero ohms " = dead shorts, not open ?
Testing fuel sending unit on Duel tank? Mrcrowley Chevy Truck Forum 76 12-03-2009 06:23 PM
Fuel Sending Unit jessewd10 GMC Truck Forum 2 04-06-2009 09:26 PM
sending unit liftedtrucks4me Ford Truck Forum 3 09-23-2008 06:38 AM
fuel sending unit ? outdoorsman Toyota Truck Forum 4 09-13-2006 01:41 AM
help on fuel sending unit utah86gmc Chevy Truck Forum 6 03-30-2006 10:16 PM
