Results 1 to 7 of 7
Thread: 1989 F350 7.3 nonturbo Diesel Start Problem
    Jan 2010
    Glendale Arizona
    55
    Question 1989 F350 7.3 nonturbo Diesel Start Problem
    Need some help. I have a 1989 F350 7.3 non-turbo Diesel that doesn't start up in the morning when its cold or hot. have to use starting fluid to get it started if it sits for more than 6 or so hours. Any ideas?
    Dec 2007
    1,645
    Sounds like you have an air intrusion problem causing fuel to drain back when it sits for any length of time. The most common cause of this is bad fuel return lines (pipes that run between the fuel injectors). Fitting a new return line kit usually solves the problem.
    Another cause could be bad glowplugs. How long does your Wait To Start light stay on? When cold should be around 10-15secs. Less than that and you could have one or more bad glowplugs.
    Use as little ether as possible, easy to break piston rings on these engines.
    Auto Banned
    Nov 2009
    Tupelo Ms.
    2,687
    im with case. glowplugs or does it have an intake heater. not to familiar with automotive diesels.
    Nov 2009
    Franklinton, La
    47
    I also agree with Case bad glow plugs or it's losing prime in the fuel system and sucking air.
    Senior Member mrjohnwayne's Avatar
    Apr 2005
    Texas
    4,055
    my vote would be something with the glow plugs, either a few bad glow plugs or a malfunctioning controller, but it could be fuel related as well.
    Feb 2010
    3
    i just bought a 90 with a 7.3 and it did the same thing. i bought new glow plugs for it and it starts without starting fluid as long as it is above 20 degrees outside. if its colder than that i have to plug it in at night.
  7. #7
    Mar 2008
    N.Y.
    10,841
    Blog Entries
    1
    i agree with checking the glow plugs, since it starts with the block heater. something else to try is to double cycle the glow plugs before trying to start it, however if there are too many bad ones it won't help
  1. 2002 Ford f350 diesel trouble
    By speedcrazy58 in forum Ford Truck Forum
    Last Post: 04-18-2008, 01:49 PM
  2. Replies: 0
    Last Post: 02-04-2008, 12:17 PM
  3. 1989 Chevy S-10 won't start
    By raydqt in forum Chevy Truck Forum
    Last Post: 01-07-2008, 02:39 PM
  4. 1989 chevy truck won't start
    By woodman13 in forum Chevy Truck Forum
    Last Post: 07-13-2006, 05:01 AM
  5. F350 diesel door ajar light problems
    By be4969 in forum Introductions
    Last Post: 05-24-2006, 01:06 PM
