Results 1 to 7 of 7
Thread: 1979 F150 - good brakes soft pedal?
    Apr 2011
    Grafton, Wiscosin
    3
    i've got a little problem. i've got a 1979 ford F150 with the inline 6. i put all new lines and new rear wheel cylinder along with a new power booster and master cylinder. my problem is that i've bleed the master cylinder and the lines mulitple times now and the pedal still is soft, there's brakes n they stop good but the pedal is still soft. it there any way to tighten up the pedal so it's not so soft n drop 1/2 down to the floor? any help would be great because i've run out of ideas!!
    Dec 2007
    1,645
    Have you adjusted the rear brakes up?
    Mar 2008
    N.Y.
    10,836
    Blog Entries
    1
    sounds like air, if you hold the pedal down hard does it continue to weep down?
    Apr 2011
    Grafton, Wiscosin
    3
    thanks case ill have to try that an seen!
    leolkfrm no it feels like their mannual brakes they compares down then get rock hard to stop the truck n some times they'll lock up if pressed to hard!
    Senior Member Lonesome7.3's Avatar
    Jul 2008
    Columbus GA
    4,975
    Are you sure the new power booster is working?
    Apr 2011
    Grafton, Wiscosin
    3
    i adjusted the rears n they helped alot so i think thats the problem
  7. #7
    Jul 2008
    Columbus GA
    4,975
    Yep, those Sterling drum brakes are known to be problems. The rear end is great but the brakes suck. That is why I am swaping in some rear disk brakes.
  1. 91 GMC soft brake pedal
    By GMCMark in forum GMC Truck Forum
    Last Post: 12-17-2010, 07:48 PM
  2. Soft pedal
    By jessewd10 in forum GMC Truck Forum
    Last Post: 10-11-2010, 08:15 PM
  3. Soft Brakes
    By MAKINO35 in forum Mazda Truck Forum
    Last Post: 01-01-2010, 09:12 AM
  4. Soft Brake Pedal
    By rmarino57 in forum Chevy Truck Forum
    Last Post: 10-12-2009, 11:24 AM
  5. where do i buy soft contact lenses
    By og25 in forum Off-Topic
    Last Post: 05-16-2009, 05:53 AM
