Old 03-07-2005, 09:25 AM   #1
counterstrike52 is on a distinguished road
Unhappy Please need help with my explorer
ok i have a 4 door 1991 ford explorer, i went to clean the air filter and i got all the dust out of it i put everything back and now the truck stalls from time to time and has trouble starting. What could be wrong??
counterstrike52 is offline   Reply With Quote
Old 03-07-2005, 12:52 PM   #2
Senior Member++
DodgeChick's Avatar
DodgeChick is just really niceDodgeChick is just really niceDodgeChick is just really niceDodgeChick is just really nice
Are you sure you put the air filter back in correctly? It could be causing a malfuction.
Howcome you didnt just replace the air filter instead of cleaning it? Wouldnt that have been easier?
2002 Patriot Blue Ram 1500 4x4 in the process of some mods
*****Voted Best Truck on HGS*****
Silly boys!! Trucks are for girls!!!
"Grab Life By The Horns"
DodgeChick is offline   Reply With Quote
Old 03-13-2005, 02:14 PM   #3
wildman89 is on a distinguished road
agreed^as above
++++++FORD LOVER++++++
wildman89 is offline   Reply With Quote
Old 01-05-2006, 10:52 AM   #4
CARL is on a distinguished road
Hay counterstrike I had the same problem. try cleaning the air flow sensor located on top of the air cleaner box. spray with carb cleaner. let dry. should work.
CARL is offline   Reply With Quote
Old 01-05-2006, 05:54 PM   #5
Ford4x4Chik27's Avatar
You can take yer air filter OUT and it wouldn't matter. I'm with CARL on this one... maybe yer Mass Air Flow Sensor is clogged or malfunctioning
good luck!!!
Old 01-05-2006, 08:24 PM   #6
chevyguy's Avatar
Check all the hoses from the air box and make sure you got all of them reconnected, this is a known killer,
USMC 92-96 USCG 98 to present
Old 01-05-2006, 10:46 PM   #7
Itstali25's Avatar
Itstali25 is on a distinguished road
check the wire going to your MAF, make sure its plugged in real good, might help
http://www.cardomain.com/ride/644045
Trucks are just cars when they grow up!!!
If your gunna get a truck....Get a TRUCK!!
Itstali25 is offline   Reply With Quote
Old 01-11-2006, 01:39 PM   #8
Well?????? How's it comin?
Old 01-26-2006, 10:38 PM   #9
superluber is on a distinguished road
Thumbs up
Counterstrike52,
FYI. Last May, after a dozen years and 120,000+ miles, we finally traded our 1991 Explorer in for a 2001 Expy. The old Explorer was starting to do too well at living up to one of the more crass nicknames (Exploder). It did pretty well for most of the 12 years or so we owned it, but it could not handle our new pop-up camper in the mountains of AZ. (We sure as heck could never rely on it for going to the big mts. of CO or UT.) But I spent more than a year trying to diagnose a problem that might be related to yours. At first it was pretty much intermittent, but then got pretty bad.
If cleaning the MAF and checking the electrical connection to it hasn't
helped, you might check the throttle body. Afer several independent techs looked it over, and 2 trips to the dealer service dept., we finally found that both the throttle body air horn and the butterfly plate were badly worn. (OK, so butterfly mat not be the correct name, but it looks like the butterfly in the old carburetor chokes.) What I am calling the air horn is the most forward part of the throttle body where the rubber hose air intake from the air filter housing clamps on.
What we finally found was the both the t-body and the "butterfly" were so badly worn on one side that too much air was going past when closed, and when releasing the throttle to idle down, it would stick. The "butterfly" had actually rubbed away part of the t-body housing, so that there was a ridge that would sometimes cause it to not be able to swing all the way closed. The inside of the t-body at that point looked something like the inside of an engine cylinder where the piston rings would wear the cylinder wall only up to a certain point at the top of its travel.
Because of the spring loading of the moving parts in the t-body, the wear was all on the passenger side of the t-body. Even if this is not the cause of your trouble, you may want to keep an eye on it.
I know this was kind of a long reply, but I thought a more complete reply here might reduce the back and forth stuff that we see sometimes.
Good luck, and let us know how it turns out.
superluber is offline   Reply With Quote
Off-road muscle back in fashion for Ford Explorer (Seattle Times) trucknews Truck News (headlines) 0 09-09-2005 09:30 AM
QCTimes.Com: Top Jobs: FORD '97 Explorer XLT 4x4 (Quad-City Times) trucknews Truck News (headlines) 0 08-30-2005 07:30 AM
QCTimes.Com: Top Jobs: Ford '02 Explorer Sport Truck (Quad-City Times) trucknews Truck News (headlines) 0 06-13-2005 11:30 PM
QCTimes.Com: Top Jobs: FORD '91 EXPLORER 4X4 (Quad-City Times) trucknews Truck News (headlines) 0 04-20-2005 11:30 AM
Explorer wont start DesertRacer Ford Truck Forum 0 11-13-2004 04:39 PM
