Old 07-05-2005, 08:34 AM   #1
George911 is on a distinguished road
Question Transmission Help Needed
I have a 1990 Bronco 2 4x4 with a V-6 2.9 engine and it has an AOD Transmission in it that has gone bad and has to be changed....My question is that my neighbor has a 1987 Bronco 2 with a V-6 2.9 engine and the same transmission I have in mine..... The only difference is my Bronco has the shifter on the column and his transmission shifter is on the floor and I was wanting to ask anyone if they know if I can interchange the linkage and make the transmission work in my Bronco....Any help at all would be appreciated...Thanks..
George911 is offline   Reply With Quote
Old 07-07-2005, 04:41 PM   #2
Ford4x4Chik27's Avatar
Yes you can rearrange the linkage. I don't konw how as I've never had to do it. I think it would be easier to swap it to the floor as opposed to the steering column... Good luck!
Old 07-11-2005, 03:57 PM   #3
Thumbs up
Thank you for the infomation on changing the linkage...
Old 07-11-2005, 05:48 PM   #4
No prob, that's what we're here for
Old 07-28-2005, 05:07 PM   #5
you shouldnt have to change anything at all. If the transmissions are both aod's then it doesnt matter where the shifter is located in the car. it still connects to the same place on the transmission.
Old 07-28-2005, 08:00 PM   #6
He'd have to change the shifter from or to the floor or column.... since one is mounted on teh floor and the other on the column..... ???
Old 07-31-2005, 04:23 PM   #7
no cause the linkage still bolts to the same place on the transmission. regardless of floor or column mount they both end up at the same place under the car.
Old 08-02-2005, 11:35 AM   #8
But what about once it's in the vehicle, something's gotta be set up inside the vehicle..that'd be part of the linkage... *scratches head*
auto transmission won't shift and rpm& speed guages don't work gmcer GMC Truck Forum 13 05-04-2006 08:27 AM
transmission help please Hollywoodk3 GMC Truck Forum 6 09-19-2005 10:08 PM
PART TIME TRUCK DRIVER NEEDED (Gaston Gazette) trucknews Truck News (headlines) 0 03-27-2005 03:30 AM
STRAIGHT TRUCK DRIVERS NEEDED (Gaston Gazette) trucknews Truck News (headlines) 0 11-05-2004 07:30 AM
STRAIGHT TRUCK DRIVERS NEEDED (The Gaston Gazette Homepage) trucknews Truck News (headlines) 0 11-05-2004 05:30 AM
