Old 12-07-2005, 09:31 AM   #1
Schrodes is on a distinguished road
Arrow Transmission fluid??
I have a 1995 Ford Ranger with a 5 speed manual transmission. I need to change the fluid in my Transmission however, the haynes manual I have says to fill it with automatic transmission fluid. I thought it would be more like a gear oil or something i needed to fill it with? What have you guys all used to fill your manual transmissions?
Schrodes is offline   Reply With Quote
Old 12-07-2005, 12:33 PM   #2
chevyguy's Avatar
Hypoid gears, Go with ATF, this is a common mistake that costs alot of money in transmission repairs.
Old 12-07-2005, 07:44 PM   #3
justatech is on a distinguished road
usually take merconIII
justatech is offline   Reply With Quote
Old 12-08-2005, 01:00 PM   #4
390FE's Avatar
390FE will become famous soon enough
Yep the newer trannies (manuals) have tight tolerances and require a thinner than gear oil lube in them. I have used ATF in a 2000 Ford focus manual(friends car), heavy duty diesel 5w30 in the same tranny (differant car), and recently put some Amsoil Synthetic 5w30 (made for Manual transmissions, a fairly new product)Syncromesh Fluid in my personal Ford Focus.
I first out the recomended 75w80 into the 2000 focus and she could not shift the car at all, she has to use 2 hands to get it to the next gear. Switch her over to the ATF and she was back to normal or slightly better than before the gear lube swap.
390FE is offline   Reply With Quote
Old 12-12-2005, 01:52 PM   #5
chevyguy's Avatar
Just follow manufacturers recommendation and you will be fine.
auto transmission won't shift and rpm& speed guages don't work gmcer GMC Truck Forum 13 05-04-2006 07:27 AM
Blazer Transmission mikerike Chevy Truck Forum 8 11-19-2005 09:50 PM
Transmission help damarr30 Dodge Truck Forum 2 10-29-2005 11:09 PM
Transmission Help Needed George911 Ford Truck Forum 7 08-02-2005 10:35 AM
allison transmission problems? Sandy C GMC Truck Forum 2 03-17-2005 05:45 AM
