Old 01-08-2006, 07:09 PM   #1
dw74 is on a distinguished road
1999 f250 rear brakes
I am having trouble with removing the rear rotor on my 1999 F250. It has a full floating axle. I have removed the special lock nut, the axle, but the rotor will not slide off. It is loose,but will not pry off. Can anyone suggest some way of getting the rotor off without using a sledge hammer.
dw74 is offline   Reply With Quote
Old 01-09-2006, 07:41 AM   #2
390FE's Avatar
390FE will become famous soon enough
Loosten the adjuster. even tho you have the p-brake off and not pushing on the pedal the brakes are probably still really close to the drum and holding it on. Loosen the adjuster to bring the pads away from the drum and they should slide right off.
By lock nut you mean the nut or screw between 2 of the studs that holds the drum on?
390FE is offline   Reply With Quote
Old 01-09-2006, 06:20 PM   #3
chevyguy's Avatar
Umm I am assuming you mean the DRUM wont slide off? Or am I wrong in thinking this had rear drum brakes instead of rear disks? If it is drum be sure your parking brake isnt set ( i had to say it, i have seem it before) and back the adjuster off a few turns. i usually take a large shot mallet and hit the drums a few times on the rear and front to center up the pads and they usually fall right off without backing off the adjusters.
Old 01-11-2006, 12:36 PM   #4
Ford4x4Chik27's Avatar
Ford4x4Chik27 is just really niceFord4x4Chik27 is just really niceFord4x4Chik27 is just really niceFord4x4Chik27 is just really nice
If it IS in fact drum, (I think so) then you have to pull the axleshaft and all that fun stuff out... at least on my truck I do
'93 Isuzu Amigo, Toyota Axles/Tcase/Drivelines, 35" MTR's. '01 Pathy, DD.
A fact of life: After Monday and Tuesday, even the calendar says W T F.....
1998 GMC Suburban Brakes seadog GMC Truck Forum 7 01-17-2006 07:32 PM
brakes overheat bigtime but i replaced everything jazzzmonky Ford Truck Forum 8 11-13-2005 10:55 AM
The vehicle, an lder sedan, slid under the rear of the truck and was crushed as far back as the rear (Chico Enterprise-Record) trucknews Truck News (headlines) 0 09-30-2005 12:30 AM
1996 Chev PU 4x4 1/2 ton rear brakes question midnightmagic Chevy Truck Forum 1 07-28-2005 04:28 PM
Rear Gear Oil benhughes85 Ford Truck Forum 2 07-18-2005 08:44 AM
