Old 02-06-2006, 02:03 PM   #1
smarti01 is on a distinguished road
1980 F-100 Fuel Problems
I have a fuel problem... the gas is not getting from the tank to the fuel pump. It is a mechanical pump on the motor and seems to be working OK, but if I pull the gas lines off they are totally dry and are not pulling from the tank. The truck was last used about 2 months ago then sat since, there was no problem last time I used it. There is gas in the tank.
Any suggestions?
smarti01 is offline   Reply With Quote
Old 02-06-2006, 03:58 PM   #2
Moderator
I would suspect either a hole in the line, or it is clogged somewhere between the tank and the pump.
Old 02-06-2006, 05:36 PM   #3
shopratles's Avatar
shopratles is on a distinguished road
If there is a rubber diaphram in the pump (which I believe there is), my quess is it is now shot. Fuel pumps are cheap, go ahead and replace it.
Good luck.
shopratles is offline   Reply With Quote
Old 02-08-2006, 03:16 AM   #4
Thanks
Thanks for the info. There is a leak in the tank so I need to change it anyway and that will be a good time to check all of the lines and the pump.
Old 02-09-2006, 09:10 PM   #5
chevyguy's Avatar
1.Have you tried to prime the pump? 2.How do you know the pump is working properly if no fuel is moving? 3.have you checked the fuel filter on the frame rail for clogging? I need more info to really halp you out here.
Old 04-01-2006, 07:36 PM   #6
mslwpk's Avatar
mslwpk is on a distinguished road
I have an 80 F100 did the same thing.. We had to chang to a electric pump and we also had to drop the tank and clean it out and replace the float and sock.Good luck!
mslwpk is offline   Reply With Quote
Old 04-02-2006, 10:28 AM   #7
chevyguy's Avatar
Sounds like pin the tail on the problem to me. I would disconnect the fuel line at the filter , check the filter. If it passes then push some compressed air back thru the lines into the tank. If it is clogged you will know without pulling the whole tank out for nothing. Just my 2 cents here.
Old 04-06-2006, 07:11 AM   #8
390FE's Avatar
390FE will become famous soon enough
Another trick. I learned this but you have to be real careful and need a 2nd set of eyes. I have only done this once with a mechanical fuel pump motor.
take the hose off the fuel pump and then have your buddy watch it. Go to the tank filler and while trying to cover the openiong as best as possible shoot some air from a compressor into the tank (If your not careful and put too much pressure in the tank you will pop it). if you see gas come out the line than everything up to the pump is ok.
390FE is offline   Reply With Quote
Old 04-06-2006, 02:43 PM   #9
BornToRide's Avatar
BornToRide is on a distinguished road
make sure to check all the lines so none have a hole or are clogged if not you may be needing to look into a new fuel pump.
BornToRide is offline   Reply With Quote
Old 04-26-2006, 02:25 PM   #10
Well, I figured it out.
I crawled under the truck to check the fuel line from the tank and to my surprise it fell off in my hand. The line had rusted through at the tank. I dropped the tank and found it had at least 10 holes in it as well.
I'm off to the parts store for a new tank and fuel line tonight.
Thanks everyone for your replies!
Scott
4x4 and fuel guage problems? nate3436 Chevy Truck Forum 1 01-31-2006 05:28 PM
1987 throttle body fuel pump problem wojeepster Chevy Truck Forum 9 12-01-2005 03:26 PM
2005 Duramax Diesel Fuel Economy Problems bruce GMC Truck Forum 5 07-24-2005 11:36 AM
Fuel Pump Problems p_kotenko Dodge Truck Forum 3 07-10-2005 07:45 AM
Nuvera Provides Fuel Cell System To Deere & Company (Asia Pulse via Yahoo! Australia & NZ News) trucknews Truck News (headlines) 0 03-15-2005 07:30 PM
