| rear main oil seal 2000 f-250 super duty mine is leaking ,have any of you replaced this seal ?did you go through a dealer and if so how much am i looking at it costing or can i do it myself .it has a auto transmission . thanks |
| depends on if it is a 1 piece or 2 piece. take it to a dealer if it is a 1 piece, involves dropping trans. alot of work unless you know someone who has a lift. if it is a 2 piece then drop the pan and unbolt the cap, you may have to unbolt the motor mounts and lift the engine to get the pan out. push the old seal out with a dowel or old chop sticks makeing sure not to scratch the block or the journal. make sure everything is clean before re-installing everything. torque the cap bolts to specs or you'll ruin your engine over time. pan gasket and seal cost around 25-50 dollars. hope this helps.
| rear main seal thanks for the info i have all the tools to do it but the time lol thanks for the info though |
| rear main seal well it turned out not to be the rear main it was the gaskets on the oil pump |
| nice to hear, it's nice when things go better then planned on rare occasions.
| 76 Chevy 454 - massive oil leak in rear of engine | MrDavidOgle | Chevy Truck Forum | 22 | 06-24-2009 08:03 PM |
| rear window seal | all4fun222 | GMC Truck Forum | 2 | 12-16-2005 04:35 PM |
| Newly Redesigned Ford Super Duty Pickup Truck (About.com) | trucknews | Truck News (headlines) | 0 | 08-13-2004 03:30 AM |
