Old 08-17-2006, 08:16 PM   #1
Fresh96 is on a distinguished road
Unhappy Whinning f150 4.9L straight 6
Have a problem Truck has been making this annoying whinning sound...Thought it was the Power Steering pump, change it still same problem...changed the smog pump still the same problem...so if anyone has any ideas please help...thanks alot.
Fresh96 is offline   Reply With Quote
Old 08-17-2006, 08:40 PM   #2
devildog75's Avatar
devildog75 is on a distinguished road
wheres the noise coming from?
devildog75 is offline   Reply With Quote
Old 08-17-2006, 09:16 PM   #3
Ford4x4Chik27's Avatar
Check your tranny fluid
Old 08-24-2006, 10:57 PM   #4
The whinning noise is coming from one of the Pulley's
Old 08-25-2006, 01:11 PM   #5
Idler pulley? That would mean the bearings inside the pulley are gone out. Easy replacement Cheap part
Old 08-28-2006, 09:07 PM   #6
chevyguy's Avatar
Check the idler, If it doesnt seem rough, Check the A/C compressor,put some dish soap on the belts when the motor is shutoff, then start it, see if it stops whining for a short time, if it does, change the belts. If not then keep removing belts to eliminate each component.
USMC 92-96 USCG 98 to present
Old 09-01-2006, 05:58 PM   #7
Thanks man, that seemed to be the problem
Old 09-03-2006, 09:27 AM   #8
So did you put soap on it or did you replace it? Glad you got it worked out!!
STRAIGHT TRUCK DRIVERS NEEDED (Gaston Gazette) trucknews Truck News (headlines) 0 11-05-2004 07:30 AM
STRAIGHT TRUCK DRIVERS NEEDED (The Gaston Gazette Homepage) trucknews Truck News (headlines) 0 11-05-2004 05:30 AM
