Old 08-22-2006, 06:50 PM   #1
39.5 F-350 is on a distinguished road
F-350 driveshaft problems
Ok first off i have a 2000 F-350. It has a 8" lift with 39.5" tires. THe problem is i keep breaking the U-Joint because right out of the transfer case it all of the sudden take a huge drop. THe driveshaft is angled to much i need some suggestions on what to do because i really dont want to have to lower it. Thanks
39.5 F-350 is offline   Reply With Quote
Old 08-22-2006, 07:12 PM   #2
Ford4x4Chik27's Avatar
Get a high angle driveline
Old 08-22-2006, 07:34 PM   #3
WHat does that do for the u joints because there at such an angle they hit
Old 08-22-2006, 07:42 PM   #4
I believe they can design a driveline with a CV that'll pull the angle. I've got quite an angle on my Amigo. It's less than 2' long because of how tall it is and how far back the T-case is... I'm sure one can be designed to handle your angle.
Old 08-22-2006, 08:19 PM   #5
72'CaminoKid's Avatar
a cant you get a kit to lower the tranny some, so the angle aint as bad?
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 08-22-2006, 08:41 PM   #6
I PM'd you a link that you might check out
Old 08-23-2006, 07:29 PM   #7
chevyguy's Avatar
Way too much drive angle. Probally bottoming out the travel, or the wrong angles. Lift it a bad thing to do if you go overboard.
USMC 92-96 USCG 98 to present
Old 11-06-2006, 09:38 PM   #8
dezineer is on a distinguished road
I have seen the transfer cases in this scenario actually rotated and remounted to lower the angle. Also, you can purchase spacers that will also decrease the seveity of the angle... Also,depending on who built your lift kit, they should have a resource for you as well, as I am sure they encounter similar complaints all the time. They may even have a premade mount available to rotate your transfer case that will keep the geometry perfect...
In custom apps I have actually seen the front "pumpkin" rotated up to a near 45 degree angle to cut the angle there as well....4links and ladders go a long way in preventing this damaging scenario as well
dezineer is offline   Reply With Quote
Guy Problems Dakotah Off-Topic 46 05-06-2009 02:16 PM
4 Wheel Drive Problems 92BlueZ71 Chevy Truck Forum 7 03-12-2006 03:22 PM
Driveshaft Issues with '05 Frontier, 4 cyl., 2WD, KC, AT onpoint05 Nissan Truck Forum 1 02-15-2006 06:42 PM
Info for everyone with accel problems speadphreak Chevy Truck Forum 2 01-04-2006 06:24 PM
98 electric problems 98Z71 Chevy Truck Forum 4 08-20-2005 07:39 PM
