Ford Truck Forum - Enthusiasts can discuss ford trucks, accessories, etc. |
#1 (permalink) |
1982 F150 stepside.Have it down to the wiring. The previous owner liked to go around probs instead of fixing them, so I have pulled lots of rigging out and am repairing existing wiring. Got all of it working except brake lights. Power coming out of the brake light switch properly (light green), Wire from the lights intact to the fire wall (purple). Can't tell where the purple and the light green meet. My diagram shows the output fom the switch going to the harness on the steering column, but not how it gets to the stop lamps. Any ideas???
Thanks |
#5 (permalink) | |
#6 (permalink) |
Moderator
The stop lamp and turn lamp use the same element in a dual element bulb (same circut). You should have 1157 bulbs back there. They might of just misprinted it.
John Wayne 2000 F-350 7.3L Powerstroke 4x4 |
#7 (permalink) |
Make sure everything goin from your fuse box is legitimate
'93 Isuzu Amigo, Toyota Axles/Tcase/Drivelines, 35" MTR's ![]() '70 f250, 3" lift, 35" boggers, dual flowmasters, decent 360. |
| brake light problem | ramdodge | Dodge Truck Forum | 5 | 09-18-2006 06:05 PM |
| 1990 chevy 1500 problem e brake light | josh030181 | Chevy Truck Forum | 2 | 08-27-2006 11:29 AM |
| Brake light heartaches | searay25 | GMC Truck Forum | 2 | 08-18-2006 04:10 AM |
| Engine and overdrive light | chief | Ford Truck Forum | 2 | 03-30-2006 06:27 PM |
| Check Engine light and overdrive light on | chief | Introductions | 0 | 02-05-2006 07:12 AM |
