| Junior Member Join Date: Oct 2006
| I gettin an F-150 with a 6in lift and 35in tires can I use stock brakes if not can some1 tell me what kind of brakes I need |
| Not sure that I understand the question. Are you asking if the original brakes will stop the truck with 35" tires? The answer is yes, no worries. The truck will not stop as well as when it had little tires, but you will be alright with what you have. Later down the road if you are not satisfied with the braking power, you might consider a rear disc conversion, if the truck is not already equiped with them. Hope that was what you were looking for. |
| As long as you install extended braske lines it should be fine.
| It should already have extended brake lines if it's already lifted on the tires.
| Brakes? | Beaver3000 | GMC Truck Forum | 6 | 09-03-2006 01:51 AM |
| bleeding brakes | jims | Ford Truck Forum | 3 | 01-20-2006 11:24 AM |
| 1998 GMC Suburban Brakes | seadog | GMC Truck Forum | 7 | 01-17-2006 08:32 PM |
| Investigators find that logging truck had no brakes (New Bern Sun Journal) | trucknews | Truck News (headlines) | 0 | 03-24-2005 11:30 PM |
| Engine brakes spark uproar (The Hawk Eye) | trucknews | Truck News (headlines) | 0 | 11-08-2004 11:30 AM |
