| 94 F-150 300 Missing I have developed an erratic miss at a constant speed thru all ranges. I have checked or replaced all the easy stuff. Plugs, wires, fuel filter,fuel treatment, cap and button. It seams to be more pronounced at normal operating temp. Been driving for two weeks, not getting better or worse. |
| I don't know exactly what it is, but chances are it's in the electronic area. Either ignition or engine control chip. I had something similar once that stumped everybody, and it turned out to be corrosion in the coil wire. |
| could be a coil breaking down. |
| Junior Member Join Date: Feb 2007
| have you checked or replaced the air filter? This sounds like a mixture misfire not electric. Check for vacuum leaks and or stuck open or closed injectors. Its a ford, good luck. |
| Body found; most likely man missing since May 31 (Desert Dispatch Online) | trucknews | Truck News (headlines) | 0 | 08-21-2005 07:30 AM |
| Nuclear-Testing Gauge Missing After Falling Off Truck (WGAL 8) | trucknews | Truck News (headlines) | 0 | 04-27-2005 03:30 PM |
| Search continues for missing fertilizer truck in WA (Fox 12 Oregon) | trucknews | Truck News (headlines) | 0 | 11-17-2004 01:30 PM |
| Chemical-laden truck missing (The Spokesman-Review) | trucknews | Truck News (headlines) | 0 | 11-17-2004 03:30 AM |
| LAS VEGAS, NV, September 2 Missing Vegas teen found following overnight search (KRNV) | trucknews | Truck News (headlines) | 0 | 09-02-2004 09:30 AM |
