Old 01-29-2007, 06:03 AM   #1
chief is on a distinguished road
1996 Ranger with no heat
My ranger will not, well some times, blows a little heat. I have had the thermostat changed, and checked the antifreeze. The truck runs at normal operating temp until I turn on the heater and then the temp gauge bottoms out. The heater hose feels warm and so does the core. I would appreciate any help. Thanks - Freezing in TN
chief is offline   Reply With Quote
Old 01-29-2007, 07:07 AM   #2
1saxman is on a distinguished road
The heater hose should be at 200 degrees, way too hot to hold. Replace the radiator cap. Check the coolant surge tank every morning after use the previous day to see if coolant needs to be added. I believe your cooling system has air in it from a non-functioning radiator cap. Coolant is simply not getting to the heater core. It could also be something as simple as a cracked hose from the rad to the surge tank.
1saxman is offline   Reply With Quote
Old 01-29-2007, 04:11 PM   #3
I have now replaced the thermostat, the radiator cap, the heater relay switch, and added antifreeze lost in the swith change. Still cold air, dang it! Any of you folk know of anything else to try or is it time to give up and take it in? I hate to do that.
Old 01-29-2007, 05:15 PM   #4
791ton's Avatar
791ton is on a distinguished road
take the cap off and let it run at idle. watch for air bubbles in the radiator. This is known as burping the system. Also watch for the water level to drop when the thermostat opens.
1979 Crew Cab Chevy
1 Ton Dually
454
791ton is offline   Reply With Quote
Old 01-30-2007, 02:05 PM   #5
Bull's Avatar
Bull is on a distinguished road
I had the same problem on my 97 F150, I finally found the problem was the water pump. It didn't leak but after replacing everything else I changed it and the blades on it were worn out.
Bull is offline   Reply With Quote
Old 01-30-2007, 05:14 PM   #6
Good call - I forgot about that. Cavitation actually erodes the impeller blades away. Doesn't this usually make the engine run hot?
Old 01-31-2007, 07:32 AM   #7
Bull's Avatar
Mine didn't run to hot, it was at the top of the nornal range but the impeller was worn so bad it looked like a skill saw blade
Old 02-13-2007, 09:20 PM   #8
btooling is on a distinguished road
Just a thought!!
My 99 Ranger starter the same problem, I did the same things that you did. I may be off in left feild but, my problems plaged me for 6 months off and on until, the Head gasket blew. I personally belive that my gasket was slowly leaking compresson back into the coolant system untill it finally blew completely out. One indication was that my antifreeze would turn rusty prematurly, and It would lose water and never suck it back from the resevoir. Like I say, just a thought, I would check for excessive moisture from the tailpipe. I am a "have to be mechanic" rebuilt the heads, reinstalled and in 50 miles it spun a rear main. In the middle of a total overhaul at present. Heck You have to take the darn engine almost completley out just to get the oil pan off. This may help you head off a major failure and a major amount of time. Hope so.
btooling
btooling is offline   Reply With Quote
99 ranger oil pan removal HELP lol btooling Ford Truck Forum 0 01-18-2007 07:56 PM
No Heat !! mattymax Nissan Truck Forum 1 12-07-2006 08:31 AM
Dodge heat litlal Dodge Truck Forum 1 03-05-2005 10:40 PM
Win Ford Ranger truck in fund-raiser (The Charlotte Observer) trucknews Truck News (headlines) 0 11-10-2004 02:30 AM
1996 Ford Ranger XLT 4x4 Supercab review (Carsurvey.org) trucknews Truck News (headlines) 0 09-26-2004 06:30 AM
