Old 02-03-2007, 07:38 PM   #1
b33cpe is on a distinguished road
Exclamation 1984 460, not getting enough gas to carb, Fuel system problem? PLEASE HELP
I have a 1984 ford f-250 460 4x4. and i am getting minimal gas in the carburator causing the truck to only run for 10-15 seconds, i give it gas when it starts to die but it still dies. i ran an alternate electric fuel pump outside the truck from the tank switch over(i have two tanks), and the truck runs perfect. I have changed the fuel filter , rebuilt the carburator(and adjusted the floats), changed the fuel return valve and fuel relay, I also checked the roll over shut off valve and reset it. I also checked all the fuses. Any ideas on what could be wrong? Please help i am out of ideas.
b33cpe is offline   Reply With Quote
Old 02-03-2007, 09:15 PM   #2
You installed a temporary pump, and it runs good? The old pump is bad. Change the pump, and you should run as good as the temp pump.
Old 02-06-2007, 03:20 PM   #3
jay996's Avatar
jay996 is on a distinguished road
X 2 I agree bump
jay996 is offline   Reply With Quote
Old 02-06-2007, 03:50 PM   #4
its not the fuel pumps. Or the oil pressure activated fuel pump cutoff switch, oil pressure gauge sending unit, fuel return valve, fuel relay, caburetor, floats, inertia switch, fuel tank selector valve, or the fuses, any other ideas?
Old 02-06-2007, 04:03 PM   #5
If you bypassed the pump,and ran a temporary one, then it could only be the pump, or the common line that feeds the carb. You mentioned pumps, (plural), did you mean that? Do you have more than one pump installed in the truck?
Old 02-06-2007, 04:43 PM   #6
My truck has two fuel pumps, one for each tank.
Old 02-06-2007, 04:56 PM   #7
I am assuming that each tank acts the same way? Then you must have a clog in a regulator, or an area of line common to both pumps. Do you know where they tie together?
Old 02-10-2007, 04:05 PM   #8
Chunk is on a distinguished road
fuel tank
did you check for a filter on the end of the line in the tanks. also what about the fuel tank switch, you said that you ran the temp from there back is the switch bad and not alowing either pump to run?
Chunk is offline   Reply With Quote
1987 throttle body fuel pump problem wojeepster Chevy Truck Forum 11 10-28-2009 02:53 PM
1993 Crew Cab Dually- Fuel pump problem? RodrigoRodrigo Chevy Truck Forum 2 02-26-2007 05:27 PM
Fuel System Issue - 1989 4x4 4Runner HKforte Toyota Truck Forum 1 01-11-2007 06:41 AM
Contaminated fuel system Phil R Chevy Truck Forum 2 07-23-2006 01:00 PM
Nuvera Provides Fuel Cell System To Deere & Company (Asia Pulse via Yahoo! Australia & NZ News) trucknews Truck News (headlines) 0 03-15-2005 07:30 PM
