| Senior Member Join Date: Jun 2006 Location: Hampton, Va
| what oil and how much? i'm about to change the oil on my friend escape and he doesn't have his owners manual, so im not sure how much and what weight oil to use.. it's an: '03 escape with a 3.0 v6. i'm thinkin about 5qts. of 5w-30. but not sure. anyone know???? Last edited by 1bj; 02-05-2007 at 01:41 PM. |
| sounds good, but i would check the dipstick after the third or fourth quart to be on the safe side. once it hits the full line start it and top it off if needed. edit: make sure you don't mix up which oil it needs, not sure if ford is using synthetic or not. |
| not synthetic for that model 03 |
| Look in the car for the owner's manual and go by that. |
| reply: im not using synthetic,, and like i said in my first thread, "he doesn't have his owners manual". |
| Full Member Join Date: Aug 2006
| You need 6 quarts of 5w-20 motor oil. |
| reply: thanks... i already changed it, and it took 6 1/2qts. and i bought 5w-30. and when i went to change it, the oil cap said "5w-20". but i went ahead and used the 5w-30 |
| Junior Member Join Date: Feb 2007
| Correct me if I'm wrong, but if it's 'colder' and you want to change viscosity, shouldn't you use a thinner oil to adjust to the colder temp? |
| Yes, bj went the wrong way. Going to 5W30 on an engine designed for 5W20, particularly in cold weather, is dead wrong. Maybe it IS rocket science. |
| yeah i know, i was thinking upside down when i changed the oil... |
