| Junior Member Join Date: Feb 2007 Location: Western WA
| driveline no speak to flywheel Tried leaving the driveway today, truck no move in any gear. Any ideas? I can shift, clutch pedal moves slave back and forth, let out clutch - driveline no turn. Do clutches get stuck in the disengaged position? Is this common? What causes it? Should I hit something with a hammer (yes this IS a straight line)? Truck has rear engine cover plate. ('87 F250HD 4WD 8-460 4-sp). Or could it actually be the tranny? How do I troubleshoot this, simple things first? |
| Prabally not the trans, Its a clutch issue, gonna have to pull it to see what went wrong.
| Just so everyone could learn. Old 250 and I had discussed this problem, and it appears that he had a linkage problem with the t-case, and the crazy thing was stuck in neutral. The clutch was working like a champ, but the case was not engaged, so she no go........I believe he has a handle on it now. |
| Temporary linkage fix - why does clutch need warm up? Made a link out of aluminum with a hacksaw and drill. Got the truck off road and ran around a bit. Everything seems to work good 'nuf fer now! Thanks for the hint 75k30! When I first get in it I have to be tender with the shift or else the gears kind of grind but after it warms up this seems to get better. What causes this? |
| probably more the tranny fluid, not the clutch. my jeep shifts kinda hard until it warms up on a chilly mornin
| Awe no kidding. I missed the whole 4 wheel drive part of this post. Good thinking
| Flywheel question | 02F2504x4 | Off-Topic | 3 | 07-14-2006 07:01 AM |
| Residents Speak Out on Truck Ordinance (RedNova) | trucknews | Truck News (headlines) | 0 | 08-24-2005 01:30 AM |
| GKN Driveline supplies 4WD drivetrain for new Fiat Panda 4X4 (UK Auto Industry) | trucknews | Truck News (headlines) | 0 | 10-20-2004 11:30 AM |
| GKN Driveline supplies new Fiat Panda 4X4 27th September 2004 (UK Auto Industry) | trucknews | Truck News (headlines) | 0 | 09-27-2004 07:30 PM |
| A Man With a Moving Van (So to Speak) (New York Times) | trucknews | Truck News (headlines) | 0 | 07-17-2004 09:12 AM |
