Results 1 to 10 of 10
Thread: 7.3L hard start when cold
    Aug 2006
    9
    My 97' F-250 doesn't like to start when it get below about 35 degrees. I've replaced the glow plugs and the relay so i think that system is working. When it is cold it take several cranks of the engine for it to even start smoking. I'm wondering if it could be weak injectors or a weak oil pump. the truck has 225,000 miles and to my knowledge has had no work done to the motor. Any ideas or help will be greatly appreciated
    Senior Member mrjohnwayne's Avatar
    Apr 2005
    Texas
    4,055
    You can have the injectrs buzz tested, or have injector pressure tested, but either way gonna have to take it to a diesel shop.
    Senior Member 03chevy's Avatar
    Dec 2006
    jax,fl
    1,244
    you might want to wait and think like a truck driver. diesel fuel is thicker than gas. if you have a tank warmer then the fuel would be thiner in the cold weather and easier to start. the colder it is the thicker your fuel will be and harder to start unless you have a tank warmer to keep the fuel warm. hope that helps out
    Senior Member peterbilt's Avatar
    May 2007
    Florida
    1,966
    my dad has the 6.o powerstroke in his and in the winter time when i used to live in ohio, he plugged it in. there should be a plug in the front under the grille or in it, but if there isnt, get an electrical dip stick so you can heat the engine oil. does this help any?
    ~Eric~
    ɹǝʌo ǝɯ lloɹ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
    Senior Member PickUpGirl787's Avatar
    Dec 2006
    Illinois
    711
    not all trucks have the plug especially if you bought it where it doesnt get that cold and then brought it to a place taht does get cold
    Ashley
    My first truck was a 1988 Chevy 1500 with the 305
    My new truck is a 1997 GMC 1500 with the 350
    Apr 2005
    Texas
    4,055
    Pick up girl is right. not all came with the plug. Almost all came with the block heater but not plug.
  7. #7
    May 2007
    Florida
    1,966
    but anyone can get an electric dipstick. pick one up at auto zone for 20 bucks.
    ~Eric~
  8. #8
    Senior Member 72'CaminoKid's Avatar
    Jun 2005
    2,757
    that only helps with the oil not the gas. sorry about your dads 6.0
    99 suburban xlt
    96 silverado
    91 wrangler (my baby )
  9. #9
    Jul 2006
    3,690
    is the oil level for the HPOP full? Sometimes the checkvalve leaks, and allows the level to go low, and it has to fill again while the truck is cranking over. It would indicate a cold start problem, when in reality it is a level problem, and easily fixed with a new check valve.
    Some of the 7.3's also had a CPS troubles. I believe that tach should rise to about 100 rpm while cranking.
    Although I doubt the CPS is the trouble, I do believe the reservoir level could be giving you trouble.
  10. #10
    Jun 2005
    2,757
    alot of the 7.3's have the cps problem but generally it is indicated by the truck will start one time but not the next and if you do get it started it will cut off while driving
    99 suburban xlt
    96 silverado
  1. white smoke on cold start
    By truck067 in forum Dodge Truck Forum
    Last Post: 04-08-2007, 10:41 PM
  2. Excessive smoking on cold start
    By thetwistedgrip in forum Dodge Truck Forum
    Last Post: 03-01-2007, 12:33 PM
  3. 2002 1500 wont start in the cold
    By bigdog101197 in forum Dodge Truck Forum
    Last Post: 02-05-2007, 04:22 PM
  4. 1990 chevy truck hard to start
    By Bill Wiser in forum Chevy Truck Forum
    Last Post: 12-30-2006, 08:18 PM
  5. Hard starting, sluggish when cold.
    By prowler40 in forum GMC Truck Forum
    Last Post: 11-06-2006, 08:09 PM
