| Junior Member Join Date: Jul 2007 Location: south side of chicago
| 2005 f350 uploader dash switches I have looked in the owners manual but i cant seem to find where i would hook accessories to these switches any one know where you pick up these leads or should i hook the load up rite to the back of the switch / |
| Those are "upfitter switches" and are already hot. you will find the other ends of the harnesses in fuse box and will have to remove the access cover to get to them. These wires will have an empty end covered with a small piece of heat shrink. The switches are only hot when the ignition is on. They are as follows: Aux circuit #1 = 1936 org/lt grn 30 amp Aux curcuit#2= 1933 org 30 amp Aux circuit #3= 1934 org/yel 10 amp Aux circuit#4= 1935 org.ly blue 10 amp Good luck. |
| Senior Member Join Date: May 2007 Location: Florida
| and they are petty kool imo, so you can have a plow, and some other stuff.
__________________ 1971 Volkswagen Bus Deluxe 1998 Ford Ranger XLT "Never give up on somebody you can't go a day without thinkin' about" Eric and Jessica 1-14-08 |
| The harness to tie into is behind the fuse panel. It should have a little plastic catch on one end that you can release. The panel will tilt and the harness for the upfitter switches is behind there.
| look and looked cant find the wires first question are they under or arround the fuse pannel in the truck or under the hood ? can any one send me a picture? here is my email calumetmarinesport@hotmail.com thanks in advance |
| does this pic help? ![]()
| I have never seen that panel before - what is all that ? |
| Crab that is the integrated brake controller and the upfitter switches the OP is referring to.
| here you go man. Sorry to have left you this long. I thought you were good to go. This is a step by step procedure. http://showland.org/f350/ This includes a complete PDF file for the wiring and pictures to help you locate your wires. Do not forget that you also have 4 pass through wires located on the driverside just above the master cylinder. These are factory wires provided for your use, so you do not have to fish your own. Good luck. |
| So I snoopped the other site and I will admit they did a nice job of matching the decor of the truck. Don't like it. How long will it take to remove the "aux" labels and redo with some useful name after an install ? I also like switches i can easily reach from outside the truck without having to climb in. I don't know how common that type of grip is becoming for the brake, but I do know I have been in many situations where being able to maintain contact with that would have been a nightmare Is upfitter the new politically correct term, like sanitation engineer ? |
