Old 11-07-2007, 07:13 AM   #1
Moostang's Avatar
Effects of incorrect jump starting?
The topic of jump starting came up over on the horse forum, I was just wondering, what would be the effects to the good battery (and everything else) if you hooked hooked up the jumpers backwards? Good battery dies, just sparks, possible computer fry or all of the above?
MEOW!!
Old 11-07-2007, 07:52 AM   #2
Moderator
all of the above, and if your unlucky enough it could cause the good or bad battery to explode.
Old 11-07-2007, 02:31 PM   #3
Moderator
define backwards.
neg on positive or just hooking up in the wrong order?
member map add yourself
Old 11-07-2007, 03:14 PM   #4
Moostang's Avatar
neg on pos
MEOW!!
Old 11-07-2007, 04:24 PM   #5
Only seen it once - don't ever want to see it again.
Guy I was with installed a battery backwards with reversed polarity
on a ski lift backup system (28 battery config)
We were outside the battery room when he energized for the test.
Wound up in the snow 15' from the tower we were on.
Wasn't the blast tho, fear makes you a good jumper.
Moral of story: uh, bad idea...
Have seen folks make a striking type contact with reversed batts
and only get big sparks, but I wouldn't bet my eyes on it.
Old 11-08-2007, 11:39 AM   #6
99Ram4x4 is on a distinguished road
You will short out the good battery.
99Ram4x4 is offline   Reply With Quote
99 S10 2.2l PU Starting problem JMP99S10 Chevy Truck Forum 3 05-06-2007 04:28 PM
Suburban intermittent starting problem Dbear GMC Truck Forum 3 03-06-2007 04:40 PM
