| Senior Member Join Date: Jun 2008 Location: NY
| My 2000 chevy silverado 1500 4x4 needs a tranny rebuild and i was wondering how much this generally cost(4l60e tranny) i got an estimate of around $1600 for a full rebuild is that ab out right?? |
| Make sure you get it done by somebody reputable and a good garuntee! |
| Banned (temp) Join Date: Jul 2008 Location: OKC, OK
| Sounds about right on the price from around here. Sure you can find someone to do it cheaper, but as stated above, get a good warranty and use a reputable shop. Also ask to make sure that is including a new torque converter. Many times people get a trans job and use the same torque converter and all the sludge and shavings are passed right back into the new trans. Check your shop at www.bbb.org That is the Better Biz Bureau, see if they have any complaints and if they do, did they resolve them properly. |
| thats about going price around here for it to be rebuilt.
| around my area they go for $1,200. i got mine done for $600 by doing most of the labor. |
| Its sounds about right for all the labor and a good guarantee, I think our dodge just ran around 1200 for a std transmission from a dodge shop.
| this is suppose to be a certified tranny shop but i will have to look into the garuntee and see if they include a torque converter with the rebuild, i was wondering if you think it would be cheaper to get a new/used tranny and swap it???? if so how much does a new/used tranny go for it is a 4L65E tranny out of my 2000 chevy silverado 1500 4x4 and where is a good place to buy one? thanks |
| is there a difference btwn the 4l60e and the 4l65e tranny?, they say i need a 4l65e tranny |
| I see you are in ny, what part? what shop? |
| here is this i found i've got a 4L65E....(the GMPP version), the truck version has the same stuff in it but comes with a transfer-case compatible tailhousing. the GMPP version comes with a non-torque arm 2WD, Holden style tailhousing. (must be swapped off stock 4L60E in order to retrofit into f-body.) same weight, same gear ratios... -5 pinion planetary gearsets -hardened/shot peened turbine, stator and output shafts -hardened sun gear -hi-energy clutch packs -extra clutch in 3-4 pack -recalibrated valvebody -heavy duty low/reverse roller clutch -factory deep pan ( i replaced this with a huge BBK pan anyway.) i think that's it. basically it's your basic, lightly upgraded 4L60E. it's a nice piece to pop in if you can get it for dealer cost like i did, but otherwise it's a bit expensive
| Rebuild or buy new? | teuky | Ford Truck Forum | 4 | 06-19-2008 06:31 AM |
| sb 350 rebuild | andersonxxl | Chevy Truck Forum | 2 | 03-24-2008 09:59 AM |
| To rebuild or not to rebuild b2600i | carlsode | Mazda Truck Forum | 2 | 01-27-2008 03:38 PM |
| Carb. REbuild | 80ToyotaPU | Toyota Truck Forum | 21 | 02-09-2006 09:54 PM |
| Nv 4500 tranny rebuild tutorial/guide | tonyseahawk | Chevy Truck Forum | 0 | 06-04-2005 04:40 PM |
